Red Flag Alert!myfordeatschevys wrote:I havnt pulled the starter off yet cause the heeders are wrapped around it and i dont have a new gasket to put on it yet and do i need to use gasket sealer?
Do you have any sort of heat shield on your starter? If not I would recommend you wrap a starter blanket around it when you reinstall it. Heat from header has killed many a starter.
