speaker dalima
speaker dalima
.My 67 pickup has the factory in cab tank.I was wandering if anyone knew how to put some fair sized subwoofer in it and be out of the way
- cobraF100
re: speaker dalima
Does your Truck have a floor shifter?
If not then you could build a Center Console and put one in there.
Chris
Never Forget Our Soldiers
![Image](http://www.fordification.com/galleries/albums/userpics/10003/thumb_20%25.JPG)
re: speaker dalima
My truck doesn't have a floor shifter and I had thought about that,but I drive it quite often and I have two kids in car seats.I was afraid the console would get in the way.
I have a 78 F100 parts truck with a tank mounted under the bed.I have thougt about swaping tanks and solving the prpblem that way.The only thing is fixing the hole where the fill tube was.
- FORDification
- Site & Forum Admin
re: speaker dalima
Unfortunately, using the rear tank from the '78 won't work. The rear frame on the '78 is wider, meaning the tank is wider....so it won't fit under your '67. You'd have to find an auxiliary tank setup from the '67-'72 era and use it as a primary tank.
Ford had an auxliary tank setup which sat inside the frame on the driver's side. Or, as a dealer-installed option, you could get outside-the-frame add-on tanks for either or both sides. Either of these options would allow you to remove your in-cab tank.
There is one other option, if you're looking for factory parts. The '73-up highboys didn't have the wider rear frame like the standard pickups...it's spacing is identical to our 2WDs. If you could find a highboy auxiliary tank setup, which places the tank between the rear frame rails at the back, that would fit just right. But they're kinda rare, so don't hold your breath trying to locate one of these. There was a setup on E-bay a little while ago....I was going to snipe the auction towards the end, but the seller pulled the auction with 30 SECONDS left!![Mad :x](./images/smilies/icon_mad.gif)
____| \__
-O-----O- Keith
![Image](http://www.fordification.com/board/mysig.jpg)
![Image](http://www.fordification.com/images/forum/supercab-avatar1.jpg)
![Image](http://www.fordification.com/images/forum/bug.gif)
My '67 restoration video
-O-----O- Keith
