STICKY: Best mods or upgrades you have done to your bump?
- RebelRider
- 4x4x4crewcab
re: Best mods or upgrades you have done to your bump?
I would have never thought hub caps would be called a upgade but today
I purchased 5 of these (see attached) and WOW what a difference. I will need to punch the centers out of two of them for the front but very pleased with my purchase of 5 caps for $25.00 today.
I also scored a box of emblems (mostly 73-79), a very good L.H. hood marker F250, and a glove box door with the explorer badge and a full set of 80's 3/4 Ford hub caps. I love SWAP MEET season.
Mark
1970 Ford F-250 Crew Cab 4x4 short box
1969 Volkswagen Karmann Ghia
1999 Ford Windstar
1983 Chevrolet Silverado p/u
1990 Lincoln Town Car
1998 Lincoln Town Car
Does your truck need emblems? Check out http://www.onceuponapart.com
1999 Ford Windstar
- RebelRider
After market fuse box.
Turbo boost from Kit.
Upgrade or modify my truck you got to be kidding. I an all original type of person. Silly rabbits Upgrading and modifying is something done to wives not trucks.
- blue68
Re: re: Best mods or upgrades you have done to your bump?
briscoco wrote:Upgrade or modify my truck you got to be kidding. I an all original type of person. Silly rabbits Upgrading and modifying is something done to wives not trucks.
I agree with you in some ways, but I've got to say... there's nothing wrong in my book with upgrading to power disc brakes, power steering, polyurethane suspension bushings, dual exhaust, etc... Some things just seem necessary and make driving the truck MUCH more enjoyable and make it worth more money. .
power steering
disc brakes
lockers (front & rear)
14 bolt rear (13x3 and a half inch brakes)
Q-jet Carb
HP 60
On board air
inside cage
2 winches
The only piece in drivetrain I have not broken or replaced is the Dana 24 T/C.
Wheel well headers and flowmasters
To me every one of these mods has made it a better truck.
disc brakes
Q-jet Carb
HP 60
On board air
inside cage
2 winches
Engage Brain BEFORE Engaging Gears
72 F-250 390, NP435, Dana 24, D60, 14b, 4.88s, detroits, 2 winches, 4x4 40" tires.
- jzjames
ptodave what do you know about putting qjets on ford engines. I was thinking about it for my I6 300 and looking for a specific qjet recommendation.
Not to much,a friend gave me the one I have. Bought an adapter and put it on and it works great. I think they make different cfm models, Have no idea which one I have. Like it a LOT better than the holley I had.jzjames wrote:ptodave what do you know about putting qjets on ford engines. I was thinking about it for my I6 300 and looking for a specific qjet recommendation.
- jzjames
Ok thanks, I guess I would just look for one from a motor with a similar displacement as my 300. Thats about the extent of my idea so far.
- 72stepside
POWER STEERING !!!! Hands down #1
Disc Brakes
Crown Vic seats.
Living in Florida, A/C is gonna top power steering when I get around to it.
Disc Brakes
Crown Vic seats.
Chris
72 F100 Stepside w/ 78 300 CID
Hedman Headers
Disc Brakes
Power Steering with 3 STILL on the tree
Comfy Crown Vic Seats
71 F250 PS, PB, AC, Auto, 390
Loooong way to go on this one!
Hedman Headers
Disc Brakes
Power disk brakes.
302 2v. to 390 4v.
Eliminating some body seams.
In process of taking out the in cab tank and upgrading to the in frame tank off of a 68' F250 CS. Did not like the fuel cap sticking out of the side of the bed, so I am installing a fuel door. I found one off of a 88' Honda Prelude. I cut the quater panel around the fuel door so I can weld it as a unit to the truck. It has the perfect conture of the upper bed side. I also grabbed the fuel door release handle and cable. I will install that in the cab. I am pretty excited about this mod. I will photograph the work.
Patrick
302 2v. to 390 4v.
Patrick
- bigjake34452
changing the fluids i have done nothing yet
- crash_552
Best mod was having the gaping hole in the intake welded up. Runs like a top now!!! Oh yeah, new master cylinder. Stopping is a good thing.
Good judgment comes from experience... and a lot of that comes from bad judgment
http://www.fordification.com/galleries/ ... ?album=731
PAINT
HOT 390 #1
hardend steel C6
CD player, in door speakers
next under bed fuel tank and going from 4x2 to 4x4 (possibly Highboy)
HOT 390 #1
hardend steel C6
