What kind of problems will I have??
I might be getting a 71 4x4 frame with no motor/trans. And I was wondering how much headache will I have putting my 300 with an NP435 in the 4x4 frame?? The main thing I'm not shure about is how does the trans connect to the t-case?? All I really know about it now is that it has a divorce t-case. Witch would be easier to install an NP435 or a C6??
4x4 stuff is WAY over my head.
"Flyin High On Caffine And Copenhagen" R.I.P Chris LeDoux
60 Mercury Comet
65 Ford Econoline
72 Ford F100 on 79 4x4 SWB frame
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
Re: What kind of problems will I have??
from what little i know about the np435 and a divoreced case. is that it has a small ujointed driveshaft. that hooks the np435 and the divorced transfer case. i think you can just put them together like that. that may be the same way the c6 is too. i dont know i havent seen one in a long time. i cant remember.
- averagef250
The 2wd 435 and 300 six will drop right in. You must find a short shaft C6 and musta also come up with 4x4 auto steering column (not simple) to use an auto in a divorced case highboy.
Thanks averagef250. Now I just have to decide if I want to use my 300 or 302. I'm thinking a 300 with an NP435 would make a good combo for a 4x4 truck.
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
