![Hmmm :hmm:](./images/smilies/icon_hm.gif)
![Laughing :lol:](./images/smilies/icon_laughing01.gif)
Robroy: Thanks for your thoroughness I appreciate it! Also just to let you know I read through each and every one of the links you posted and now I think I've got all the information I needrobroy wrote:Good evening Caseys71!
I'm a beginner when it comes to prep and paint, but I've tried out a few products: Rust Bullet Automotive, Rust Bullet Black Shell, Eastwood Rust Encapsulator, and POR-15 Engine Paint. You're asking some great questions and I'm not able to respond to all of them, but here are my thoughts on these products.
As you probably already know, all of these paints contain dangerous and even deadly chemicals that you mustn't breathe. For example, both Rust Bullet Automotive and POR-15 contain isocyanate-based hardeners. Inhaling too much of this chemical can be deadly--it can stop your lungs from working, and it does very nasty things to your skin too.
To quote the Wikipedia isocyanate article, "The reactivity of isocyanates makes them harmful to living tissue. They are toxic and exposure is known to result in hypersensitivity pneumonitis as well as occupational asthma in humans, both through inhalation exposure and dermal contact. Exposure to isocyanates and their vapors should be avoided. "
Brushing these paints on reduces your risk because you avoid a lot of the vapor that's generated by using regular spray or HVLP guns. And you'll want to leave no part of your body exposed to the paints.
In my opinion, the minimum safety gear for working with these paints is:
When working with these paints, a guideline is that you should never be able to smell the paint. A quality 3M respirator will remove the paint smell 100%. If you're smelling the paint, you have a leak around your mask that needs to be fixed.
- Long pants
- Long sleeves
- Thick gloves like SAS Thickster EX (part 6603)
- Goggles that seal around your face
- A quality 3M paint respirator like the R6211 ($31 at Amazon).
Rust Bullet contains deadly isocyanate hardeners. It comes in cans and can be brushed on or sprayed through an HVLP gun with a very wide tip (1.8mm or wider). It brushes on very well and does a good job of hiding brush marks. It's also pretty fast-drying in warm weather, and it's easy to avoid drips; it's a very thick paint. It's almost like runny anti-seize compound!
Here's my frame painted with Rust Bullet Automotive shot through a Finex FX3000 HVLP.
[ Image ]
Here's Rust Bullet Automotive on an I-beam.
[ Image ]
Rust Bullet Automotive brushed on to the back of my FE.
[ Image ]
Here's my driver's side floor pan. I brushed on Rust Bullet Automotive with a throw-away hardware store brush.
[ Image ]
And the passenger's side floor pan.
[ Image ]
Here's Rust Bullet Automotive brushed on to my brake booster.
[ Image ]
This is an extremely thick, gooey paint that takes FOREVER to dry. I sprayed this on my frame and suspension pieces, over Rust Bullet Automotive.
[ Image ]
[ Image ]
[ Image ]
[ Image ]
When brushed on (instead of sprayed), it's not particularly good at hiding brush marks.
If you choose to top-coat with this product, take extra care to follow the instructions on the wait time between coats. This paint releases gasses as it dries and if you top-coat too soon, you'll get ugly gas bubbles in the finish! Same goes for Rust Bullet Automotive now that I think of it.
This stuff's convenient since it comes in rattle cans, and it sprays on nicely and dries quickly (just a few minutes). It's also available in two colors (black and red) to make it easier to see where you've already sprayed when putting on a second coat. It dries with a matte finish.
[ Image ]
[ Image ]
POR-15 Engine Paint
I have no idea if my experience with POR-15 engine paint is the same as it would have been with the regular, black POR-15 chassis paint, but I used the engine paint for the first time today. My review and some photos are in Making a T18 top end nice and tight: canes and top covers..
Caseys71, here are a few threads you may enjoy:
Durable paint in bright colors without deadly isocynates?
What safety equipment is required for paint w/isocyanates?
Which paint brushes are good for what (foam or hairs)?
Which paint spray gun should I buy for applying RustBullet?
I'd be happy to go in to more detail on the little I know about paint prep and these specific products.
Robroy
Thanks for your input, I thought about rust-bullet but I can't find anywhere local to get it and I'd like to be able to pick up the products this week so I can get to work, however I'd like to try it somewhere on my truck and will probably order some when I run out of POR-15 for the body portion of rust preventing. And I will be sure to take your advice and make sure I do the needed prep-work per POR-15's recommendationsmljjones67 wrote:Preparation is the biggest key here. I think there is a lot of paints that will work. But I personally will be using silver bullet with there metal prep.
Thanks for mentioning that your local paint store carried it as I had thought it was something I'd have to order. Turns out our local NCS Coatings here in town carries it, and for the same price as ordering it through POR-15, and I don't have to pay shippingmichael69 wrote:My local paint store carries the por15. I used it on my 67 chevelle when I restored it about 5 years ago and it still looks just as good as it did when it was put on.I'm going to use it on my 69 f100 in about a month or so. I really like it.
That looks like a pretty neat alternative Stephenstephen44 wrote:I intend on blasting my chassis, washing and degreasing and then use - SPi's epoxy - it does not need a top coat as underneath the truck - UV's cannot reach.
you can read about it here - http://spi.forumup.org/viewforum.php?f= ... 0cf1b2c39e
(hope it is ok to link this ?)
- from what I'm reading - can't be beat on quality, price or help you will get from Barry - the owner.
I think everyone has there favorite though - and the safety points are well taken and important to follow
just myworth.
- Stephen
There's some neat reading on them, if you google it, or look at the link Stephen posted you can get a good gist of it. As for explaining it them I'm of no help thereflyboy71 wrote:Whats up with 2-part epoxy primers? The guy at work that sits next to me swears by it.
just myworth.
- Stephen
