Need tips on 351W swap
Hi everyone.
I have some one building me a 351W for my 67 F100 (2WD). Heiasked me to purchace the oil pan and he suggested I get an extra capacity pan. I ve searched the web for pans but i have some questions.
My first question is...will a stock front sump clear the crossmember? Secondly, If I get a front supm t- pan will it hit the cross member?
Lastly, i could get a rear sump pan, but I don know if that will interfere with the steering. Help from anyone who has done this swap or has pictures would be appreciated. Vic
Re: Need tips on 351W swap
I have a 351W in my 68. The front sump pan will clear but changing the oil is a drag. The drain plug will dump oil all over the front crossmember. The drag link is lower than the cross member on my 68. This one will work to. http://www.summitracing.com/parts/MIL-30730/
i have a stock 351w in my 67. it fits in there fine. i dont know abou the oil pans. i guess it depends on the manufacturer.
Thanks,
I feel more confident now. are you also using a manual trans? I'think my I-300 belhousing should work
mines a auto trans. the 300 bell will bol up to the 351w and 351c
cool, this may not be so bad! Any need to shorten the drive shaft?
I am running the 4 speed toploader with the short car style bellhousing. No issue other than some alignment issues with the clutch linkage. Easy to fix if I wern't so lazy.
- AlleyCat
Nope but you'll need engine perches from a 302 truck.Vic wrote:cool, this may not be so bad! Any need to shorten the drive shaft?
Clay
yep, got those first, now the fun begins
my driveshaft is really really close to needing a few more inches in mine. what they did was to move the carrier bearing mounting location on my lwb 67. and the shaft still doesnt seem quite long enough for my comfort. but it does work. oh and my 67 with the 351w is using the fe mounts in the rear position. not the forward postion . so watch your driveshaft length. yo umay need a slightly longer one.
Mine was a short bed auto so it all worked out.
