custom gear shifter
custom gear shifter
Hi all
Im after a custom gear shifter for a 70 f100 (rat rod)
any one out there that knows of some one who has made them on.
Need on approx 26" long
Brad
Brad
1970 F100 rat rod
rear flip kit
4" dropped i-beam
silver metallic over hot rod flatz metallic matte black w/ red pinstripe
mods to come: reupholstered interior
rear flip kit
4" dropped i-beam
Re: custom gear shifter
for what transmission? floor shift or column shift? sounds like a floor shift being over 2 ft. long.
im after a floor shift manual shifter.
Something rat rod like, similar to the attached http://cgi.ebay.com/ebaymotors/Rat-Rod- ... ccessories
this is my truck
this is my truck
1970 F100 rat rod
rear flip kit
4" dropped i-beam
rear flip kit
4" dropped i-beam
that would really be pretty easy to make a custom shifter for. you would want the original shifter. so it would go into the transmission. and then cut it off below the shifter boot. or get a larger shifter boot and cut it up higher. then attach your custom rod to the stub of the original shifter with a collar and bolts through both pieces. you just have to decide on your design.
- ezernut9mm
a friend of mine lengthened his original one. it looks real cool but he can't hit a gear with it to save his life. i guess he will eventually get used to it but i laughed a bunch when he first started driving with it.
wanting to buy a mercury tailgate!
"the man who is swimming against the stream knows the strength of it".- woodrow wilson
- F100builder
Very cool truck!
I have a Lokar on mine but it's a C6. Not sure if you wanted something like a Lokar or Gennie or if you wanted something totally custom. For a manual, the sky is the limit and like fordman says, you can make just about anything you want and just attach it to the existing base.
Here's a pic of mine before and after carpet. I still want to get a knob for it with a little more attitude.
Patrick
'56 F100; Must.II IFS, 351W bored & stroked to 395c.i. 470hp/483ft-lbs., AOD, 4-link coilover 9" w/ 3.89's
'69 F100; 390, C6, Dana 60 w/ 4.10's
'70 F100; 'new' and latest project soon to have a built 390/C6 and 3.50 gears
To see more of my F100's: http://www.cardomain.com/id/lowfat56
- F100builder
Oops...accidental bump!
Patrick
- F100builder
I was looking for an excuse to add a sunroof!fordman wrote:is it tall enough?
Patrick
I thought the one posted somewhere on this site with a old glass door knob for a shifter knob was cool as heck.
that also kind of reminds me of he ratfink models cars of the 70'sF100builder wrote:I was looking for an excuse to add a sunroof!fordman wrote:is it tall enough?
- Dalton Sexton
I think he wanted a chopper but the truck was more sensible.
- radioactivelarry
I have a dummy grenade I'm going to use for a shifter knob. Or maybe I'll use a live one with a quick disconnect then I can toss it at the guy that is tailgating me!
How's that for "road rage"
Has anyone ever shortened a shifter? If so how does it work? I would think you would get a shorter throw?
Democracy is two Wolves and a Lamb voting on what to have for lunch. Liberty is a well armed Lamb.
Ben Franklin.
My Motto: I wish I had less to do, more time to do it in and got paid more for not getting it done.
Ben Franklin.
