From my knowledge most companies that make them and say they fit, they will. If you had a stock hiegth and high pinion then most won't. I had to run block huggers on mine.
Doug
What headers will work
Moderators: FORDification, Doug Comer
Re: What headers will work
1967 f100 4x4
1970 f250 4x4
1970 f250 4x4
Dougs right here, all of those should fit your needs seeing how your still running the low pinion axle up front. My highboy has a 78' High pinion an my hooker headers are beat to hell from the pinion smaking the driver side in the past.
-Mike-
ECV 1849
Build>http://fordification.com/forum/viewtopi ... 22&t=68225
69' F250 Highboy 390ci.,NP435,Dana 24,HPD44,D60
67' Dodge Coronet R/T 440ci.4speed,D60, all numbers correct
72' Dodge Dart 440ci.727,D60,10ptcage street strip on meth 10.40s
05' Chevy Tahoe LT loaded for the wife an the baby duty
12' Ford Focus Titanium Hatch Back, Gas saver for the work week
ECV 1849
- 1971ford
ahh. Good to know.
But I do plan on putting a high pinion up front in the future... now which set of headers?
I'm lifted 3ish inches, but Mike says his headers are beat and he is lifted the same. Hmmmm
-Ryan
You can't go wrong with either set you have picked out, in my small block mopar days I've ran both brands, I'm partial to hookers cuz I I own a set of 2" primary fenderwells for my 440 in the dart an there amazing an made jobs of power an they ain't nothing wrong with a Hooker if your just driving around looking lolw
-Mike-
ECV 1849
ECV 1849
- fireguywtc
I have those hooker headers on mine and they fit well, but are close to the starter by about 1/2 inch. So buy wrap if you get them. I like them because they have the thickest metal on the tube and thick and heavy flanges. They also don't have the motor mount going through the middle of them like some headers do. The bad is they don't have the exhaust flanges on the collectors so I had to have them welded on, no big deal to me.
Bill
1967 F-250 LWB 2WD 352 V8, 4spd manual, true duals, 122k original miles (currently being restored)
2024 F350 CCSB, darkened bronze
Sanderson block huggers will fit either way you go.
Doug
Doug
1967 f100 4x4
1970 f250 4x4
1970 f250 4x4
