1967 F-100 project
- 67nukeford
Re: 1967 F-100 project
Thanks, I appreciate it! I'm hoping I can get the cab support piece welded in this week, and then pray for one more day in the 70's to shoot epoxy primer on it before winter!
- FoPAR
good job, way to stick it out. It sucks but nothing better than a job well done.
"FoPar" because I love Fords and Mopars so just call me FoPar...
![Very Happy :D](./images/smilies/icon_biggrin.gif)
- tylerb43
Awesome job Pat, Looks great buddy! ![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
- 67nukeford
Thanks guys! Unfortunately, the cold weather that's moving in may slow my progress down considerably.
- 67nukeford
I was able to pick up some nice parts from one of the guys on here from Omaha, 69twotone (thanks Joe!). Got a nice tailgate, 2 fenders, and an amazingly clean radiator support!
- tylerb43
Great score, Pat! So I guess you're not getting the fenders from Riff?
That radiator support looks very good, but are you sure it's a bumpside support? Sure looks like a 73-79 support to me...![Hmmm :hmm:](./images/smilies/icon_hm.gif)
- FormerMarine1981
73-79 will still work with slight modifications if it is.
What we do in Life, Echoes in Eternity
- tylerb43
Marine is correct, it can still be used. Which maybe that was your plan all along.
http://www.fordification.com/tech/radsupport.htm
...Nod to Keith!![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
...Nod to Keith!
- 67mann
![Cool 8)](./images/smilies/icon_cool.gif)
- 67nukeford
You know, I don't have mine, and the more I look at it the more I see that it probably is a 73-79. But, I can still use it, so that's fine. I still have to get inner fenders from Riff, and the stone guard that goes between the bumper and the grill. MIght see if he's got some nice Ranger emblems also.
- 67nukeford
Next thing on the list, is this bracket that holds the front fender to the bottom of the cab. You can see what it should look like here.....
- 67nukeford
And here is what's left of the other side. Removed it to make a new one out of 16 ga. steel. Also, the rocker underneath it is shot. pretty much the only place where the rockers are bad. So, along with that steel on the corner, I'll have to weld in a patch on the rocker, before welding in the new bracket.
- Manny
Pat i don't know your labor rate but man it would be worth it you are a trip with the time a care you take into repairing your rust that cab will be better for sure than ford built them back when that one has some love in it for sure. ![2 cents :2cents:](./images/smilies/icon_2cents.gif)
- 67nukeford
Thanks Dan, I plan on pulling the cowl off also, just to make sure that is cleaned up and sealed also!
- Manny
I am telling you keep it up you will be by the house down here in Georgia to do the cab on the true blue highboy...I want to peel the cowl off mine so i am looking forward to seeing how that works.67nukeford wrote:Thanks Dan, I plan on pulling the cowl off also, just to make sure that is cleaned up and sealed also!
