I need ideas about making a license plate light work on a 1970 F 100. All tail lights work, turn signals and side markers. New bulb has been installed, still no license plate light. Not a problem unless I want to go somewhere after about six oclock, still...
Any ideas?
license plate light
- 1970F250
re: license plate light
unplug the wire that gos to it and make sure the connection is clean and corrosion free.
Steve
binder56jd wrote: If you can't dazzle them with diamonds- baffle them with b------t
- Billybobjunky
Hot-wire it into the same wire that runs from the leftside tail light to the right side one, that way when you turn on your tail lights, your license plate light also comes on. Thats what I did at least. Also, welcome to the forums! Where bouts in TX u at? There's quite a few of us round the DFW area.
1967 SWB 2wd F100
-'77 V8 [[[410]]]
-'74 C6
-Re-wired main harness
-Disc Brakes/Power Steering
-'77 V8 [[[410]]]
-'74 C6
Thanks for the info guys, I will give it a try tomorrow.
I am in San Angelo, long way all that concrete up there. Thanks again.
