Any Tips on Carpet Installation?
colnago
Post by colnago »
I just got a new carpet from NPD, and I'm hoping to install it this next weekend. Does anyone who has done this have any pointers? Any estimate on how long it will take to install? The side edges of the carpet are finished. Do these go under the door sills, or over? Do I have to do anything with (or to) the firewall shield? How about the fuel tank? The seat will come out, as I also have a new upholstery kit. Hopefully, in about a week, I'll have a much more comfy ride! :D
Thanks,
Joseph
flyboy2610
Re: Any Tips on Carpet Installation?
Post by flyboy2610 »
colnago wrote:I just got a new carpet from NPD, and I'm hoping to install it this next weekend. Does anyone who has done this have any pointers? Any estimate on how long it will take to install? The side edges of the carpet are finished. Do these go under the door sills, or over? Do I have to do anything with (or to) the firewall shield? How about the fuel tank? The seat will come out, as I also have a new upholstery kit. Hopefully, in about a week, I'll have a much more comfy ride! :D
Thanks,
Joseph
The edges of the carpet go under the door sills. You will need to tuck the front of the carpet up under the firewall cover. The tank can stay in.
Red Green
you'd better be right.
colnago
Post by colnago »
Thanks, flyboy. I was pretty sure that this was the case, but I haven't done anything like this before, and wanted to check before I got half-way into the project and didn't have a clue how to proceed (Replacing the microwave only took six trips to the hardware store, and about five hours to install. I could have bought a counter-top unit and been done in 30 minutes, but noooo, she deciced she wanted to install one over the range! :roll: ). The carpet was much bulkier than I expected, after I pulled it out of the box. Hopefully, it will flatten out some while sitting in the living room before the end of the week.
Greatly appreciate the reply!
Joseph
:fr:
CrypticRacer13
Post by CrypticRacer13 »
Pictures pictures pictures please
-Mike-
ECV 1849
CrypticRacer13
Did you ever get the carpet kit installed? How did it all go for you?
-Mike-
ECV 1849
jimmy828
Post by jimmy828 »
If you have not installed it yet ,spread the carpet out in room. Let set for a week before installing. It will be less aggravating when installing
colnago
Post by colnago »
CrypticRacer13 wrote:Did you ever get the carpet kit installed? How did it all go for you?
Yes, I did get the carpet installled. I want to finish recovering my seat (just got foam delivered yesterday, probably recover next weekend), then I'll post pics of the whole thing. After the seat comes new seat belts, then recovering the dash. I'm also in the process of repairing the cracks in the steering wheel. I'll also post before-during-after pics of the steering wheel once that is done.
Joseph
jthulan
Post by jthulan »
Updates???
1971 F100 Custom, 119,xxx miles
1984 Chevy Silverado, 437,xxx miles, original owner
1976 Ford Ranchero GT, 130,xxx miles
2015 Volvo XC60R, 60,xxx miles, daily
Clunker
Post by Clunker »
Hi colnago,
Sorry I didn't see your post before you installed the carpet, but I thought I would give my two cents in case anyone else is looking for help on this thread. I used to be a floorcovering contractor, so I know a bit about carpet. Auto carpet is totally different from the residential/commercial varieties, but the same principles apply. The secret to getting your automotive carpet to mold to the curves of your chassis is to use a heat gun. Auto carpet has a sort of plastic backing instead of the twine or nylon backing found in residential carpet. The heat gun (or really hot hair dryer) makes the plastic backing flexible, so it conforms to the shape of your interior as you install it. If you have any other questions about the carpet, feel free to PM me.
1970 F250 CS: 360, RV cam, Edelbrock Performer 390 intake, Holley 600, headers, Pertronix II, Flamethrower coil.
colnago
Post by colnago »
Okay, here are some really crappy photos of the carpet. The last one shows how nice the carpet looks in comparison with the rest of the cab. The first two photos show how much space there is between the edge of the carpet and the kick panels. You can see that the carpet runs under the door sill, but still did't stetch to the kick panel. I think Clunker is 100% correct; heat helps. I installed this kit in January, because I had to. If I installed it in April, I would have let it warm up on the driveway for the day to limber it up. I might take a heat gun to it when I have the bench seat out for the upholstery kit. I haven't cut the hole for the headlight floor switch yet, hoping that things will flow a litte bit before I do ('sides, I never use my brights, so I'm not in a big hurry).
By the way, that dark area on the passenger side isn't a shadow. The heater core decided to wait until AFTER the carpet was installed before it leaked all over everything! :x I really do like the carpet, though. It is soooo much nicer than the original rubber mats.
More photos after I install the upholstery.
Joseph
papabug71
Post by papabug71 »
Is this the best fitting carpet for our trucks? The carpet looks great, but that fit is pretty poor. I don't see it stretching to the kick panels, even if it was warmed up prior to install. Since I'm going to be going back with carpet rather than a rubber mat, I guess I need to study up on carpets.
What options besides NPD do we have for carpet?
Matt
1971 F-100 Sport Custom - My grandpaws truck
Been in the family since 10/3/'71 (Brand spankin' new)
Mine since 5/7/'94
302 / 3 speed / 3:25's
--Currently undergoing full frame off resto/mod--
Calfdemon
Post by Calfdemon »
Do you have the C6 hump in your truck? If so, you needed to order the carpet to cover the extra height since it is a bit taller than the standard hump. We ordered the standard carpet for CNM67's truck (he has a manual shift) and it fit perfectly from side to side. We already confirmed that your carpet and our carpets came from the same manufacturer (ACC). I bought the larger carpet for the C6 cover for my crew cab and while I have not installed it yet, I did lay it in the truck when I got it to see how it would fit and mine appeared to be the proper length from side to side too without any gap.
So I just wonder if you have the C6 cover in your truck and if they sent you the carpet for the standard cover. If so, that would explain that gap.
-Rich
Current toys -
Former toys -
cole71
Post by cole71 »
Yeah that makes sense Calfdemon. I ordered mine for the low hump which is what mine has, even though I've put a C6 in my truck. So hopefully mine will fit.
colnago
Post by colnago »
Calfdemon wrote:Do you have the C6 hump in your truck?
Nope. That was one thing I definitely looked into. I have a low, flat tranny hump in the truck. I do have a high bump that I was looking at installing, but since my floorboard is uncut, I'm not planning to use it. According to my manufacture plate, the truck originally came with a Cruise-o-Matic, although there is a C6 in it now.
Joseph
kf7mjf
Post by kf7mjf »
Looks nice, something I hope to do to mine this year
1967 F-100 Ranger
