Radio delete.
- chad67
Radio delete.
I am curious about something.... When Ford did the radio delete option, did they delete the dash speakers as well or were they installed, but not the radio? If they didn't install the speakers, did they use a dash pad without the speaker holes?
1967 F100 SWB
1991 Thunderbird 5.0 with fully ported gt40 heads, cobra intake (also ported) and a trickflow stage 2 cam, manual steering, and custom 3" exhaust
Re: Radio delete.
My truck came as a radio delete but had the speaker mounted and the same dash as a radio optioned truck.
- chad67
Re: Radio delete.
Thanks! I am realizing that my truck is a bit of a stange bird. It's a '67 swb custom cab with the deluxe 2-tone paint (and accompanying trim), 240 engine, 3 on-the-tree, economy heater set-up. I was trying to figure out what other options my truck came with. Is there any way to figure this out?
1967 F100 SWB
- 3 Speed
Re: Radio delete.
The 67 owner's manual lists available options in the back, and I think the literature library here on Fordification has an options price sheet for 1967.chad67 wrote:Thanks! I am realizing that my truck is a bit of a stange bird. It's a '67 swb custom cab with the deluxe 2-tone paint (and accompanying trim), 240 engine, 3 on-the-tree, economy heater set-up. I was trying to figure out what other options my truck came with. Is there any way to figure this out?
If you do not have a manual, I can scan those pages and post them here.
67 F101 Custom Cab longbed, 352 V8, 3 speed manual
- chad67
Re: Radio delete.
I found a company called Marti that can find the original build sheet an any 1967-??? Ford vehicle built. Has anyone used their service?
1967 F100 SWB
- colnago
Re: Radio delete.
I have not used them, but I have heard of them. Those who have used them have reported being happy with the info they got.chad67 wrote:I found a company called Marti that can find the original build sheet an any 1967-??? Ford vehicle built. Has anyone used their service?
Joseph
"Sugar", my 1967 Ford F250 2WD Camper Special, 352FE, Ford iron "T" Intake with 1405 Edelbrock, Duraspark II Ignition, C6 transmission, front disc brake conversion.
