Bench Seat Hardware
Flightman91
Bench Seat Hardware
Post by Flightman91 »
I have buckets in my truck and I don't really like them. I want a bench and I have one I can buy but its out of a newer Ford. What years can I use the hardware out of?
1967(ish) Ford F250 4X4. 390, NP435, Dana 24, Dana 44 front end closed knuckle 4.11 Drum brake, Dana 60 rear end 3.73 Drum brake
2005 Subaru Forrester XS manual
2009 Scion XB Auto
HIO Silver
Re: Bench Seat Hardware
Post by HIO Silver »
IIRC, up to an including 96 will swap. Otherwise, yer on your own.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
Subzero
Post by Subzero »
To my knowledge the hardware ( if you mean the base that bolts to the floor) is different after the bumpside years. I might be wrong but I know 90's hardware is different. I just did a 1994 swap in my truck and I followed what this sites tech article says on the topic about using the old base with the new seat. The base on my 94 seat has just 4 holes that bolt into the floor while a bumpside normally has 8 bolts in the floor. A new seat will fit, you just have to drill out the threads where the tracks bolt up to it so the original tracks studs can slide through and be secured with a nut.
1972 F100 Sport Custom-2WD, Aqua Blue and Wimbleton White, LWB, 302 V8 and C4 trans, P/S, P/B - under construction
Gone but not forgotten: 1968 F100 Ranger- 2WD, LWB, original rebuilt 360 V8, Autolite 2bbl carb, C6 Trans, Hedman Headers, Powermaster Racing Starter, H-Pipe and Glasspacks, P/S, P/B, A/C
mrollings53
Post by mrollings53 »
If your buckets are original, and you're dead set on changing to a bench, post them and the seat brackets on the parts for sale thread. You should be able to make a good buck off of them.
Common Sense is an Uncommon Virtue
Flightman91
Trust me I'm planning on it. But I still need a seat. So can I only use the hardware from 100s,250s, and 350s or would the bigger trucks brackets work too?
2009 Scion XB Auto
