Bench Seat Hardware
Flightman91
Bench Seat Hardware
Post by Flightman91 »
I was looking through my parts this weekend, and I found these. Is this the hardware needed to mount a bench seat?
1967(ish) Ford F250 4X4. 390, NP435, Dana 24, Dana 44 front end closed knuckle 4.11 Drum brake, Dana 60 rear end 3.73 Drum brake
2005 Subaru Forrester XS manual
2009 Scion XB Auto
cole71
Re: Bench Seat Hardware
Post by cole71 »
Yep that's it. Gonna need a piece of wire or something to be able to release the passenger side track to move the seat back and forth though. A piece runs from the driver side lever over to the passenger side. Without it you will only be able to release the driver side.
Flightman91
That is some of best news I've got on a part. I'm assuming that the one with the lever is the driver side. How do these get mounted in the truck?
2009 Scion XB Auto
cole71
Post by cole71 »
The 4 holes go on the floor of the cab. You'll see the eight total holes on your cab floor.
Flightman91
Thank you. Do the high sides go in the front or the back and do I mount them to the seat first or the cab first?
2009 Scion XB Auto
High side to front n it's easier to bolt them to the seat first. When you get it in the cab, you'll need to slide the seat forward to make it easier to get the back bolts in the floor.
Flightman91
Thanks guys, one idea what year seat belts will work? My lady would really like a shoulder strap.
2009 Scion XB Auto
