Looking for Pictures of Custom Gauge Clusters
- KRob
Hey everyone, I am thinking about building my own gauge cluster......these are some of the pictures I have found so far. I was hoping those of you that have done it before could add your thoughts and pictures! I am really not look for the F600 type, they don't appeal to me for some reason.
Thanks
Wood Gauge Cluster http://www.fordification.com/forum/view ... er#p401588
Started from a F600
http://www.fordification.com/forum/view ... er#p620290
[/quote]
What i am thinking about doing is using a metal dash and building the center....fill in the open space of a metal dash like this one.
_______________AS I FIND MORE PICTURES I AM GOING TO ADD THEM BELOW______________________
http://www.fordification.com/forum/post ... 2&p=304564
From mcheath's project
http://www.fordification.com/forum/view ... &start=135
Thanks
Started from a F600
[/quote]
71 F250 4x4, 4BT Cummins Mostly Done...Project Thread http://www.fordification.com/forum/view ... 22&t=65450
(4BT, big block ZF5, 78 NP205, 78 Dana 44 Front axle, 4.10, 265/75/16, power steering, power brakes)
01 Dodge 2500 4x4 Cummins...turned up a little.
Re: Looking for Pictures of Custom Gauge Clusters
Subscribed...
lets see some pics
lets see some pics
'68 SWB custom cab Bump. Under construction.
'66 bronco
'68 bronco
'66 bronco
'68 bronco
- KRob
Found another good one.
http://www.fordification.com/forum/view ... er#p322648
[/quote]
Thanks guys....I am really hoping we can get some pictures up for future guides.
[/quote]
- tbone6
Okay, I'll bite...here's mine, still a work in progress.
t6
1972 F100
1972 F100
- KRob
tbone6, that is a billeted one? correct? where did you get it?
Hey guys if you post pictures give a little info about them, bought or built....if built please provide more info
thanks
thanks
It looks like the ones from SNS
http://www.snsclassics.com/
- tbone6
Yes, the insert is billet aluminum. I got it here, http://www.docskustom.com . Good folks to deal with. The cluster sheetmetal is from a 1968 (all metal). The gauges are VDO and the turn and high beam indicator lights are from a Harley Davidson.KRob wrote:tbone6, that is a billeted one? correct? where did you get it?
t6
1972 F100
1972 F100
- tbone6
I do like this one, maybe done in a slightly darker stain. I might have gone this route if I had seen it before doing mine. The wood would match my plans for the A/C vents I am drawing up...KRob wrote:Wood Gauge Cluster http://www.fordification.com/forum/view ... er#p401588
t6
1972 F100
1972 F100
- thejunkman
I sorta dig our stock gauges, however if I was going to build my own, I think I'd try to go even older school. Maybe graft in some 40s ford gauges. Something outside the box. May even from the sedans of the era.
-Dave
1967 f100 long bed 2wd, 390, np435
1999 Mercury Grand Marquis
- KRob
Dont get me wrong i actually like the stock dash better.....but i am tired of dinking with 40 year old gauges. I am hoping to build this new dash with enough style of the old ones that it works.
- 67mann
Here's mine so far.....
Clock face is scanned from images here, then blended together and re scanned for final image...gauges came from ( ) ebay dealer
