Heat/AC
- Mancar1
Heat/AC
Has anyone went with the Heat/AC unit in their Bump? Just wondering how much if any better the heat is than stock.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Re: Heat/AC
If you're talking about the large factory heat/AC unit, yes I installed one in my 69. The heater does not get as hot as the heat only unit but it is still adequate. I use the AC more anyway since i live in Florida
- Mancar1
Re: Heat/AC
Thanks for the reply. May just leave it as is after hearing about your heat. I already have under the dash A/C, and my heater works ok.Mach428 wrote:If you're talking about the large factory heat/AC unit, yes I installed one in my 69. The heater does not get as hot as the heat only unit but it is still adequate. I use the AC more anyway since i live in Florida
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- abyars111
Re: Heat/AC
I changed the core and replaced all the seals for my non A/C heater and that thing will run you out of the cab now. It is hot and I'm only running a 180 thermostat. This is on a Crew Cab truck. My kids start rolling down the windows in the back.
Anthony
1970 F250 Crew Cab 2wd 390/2v short bed
2004 Eddie Bauer Expedition
1955 Chevy 210 4dr Sedan
