I recently purchased an F600 gauge cluster from hotrod ford. (Thanks again! )
I got it all cleaned up, sanded the chrome down to a nice dull finish, and got rid of all the surface rust. Time to apply the self etching primer. Problem!
From what do I hang this while painting it? Answer: the stepladder!
First coat of primer is on and drying as I type this. Second coat will go on, be allowed to dry, and then the cluster will dry at least 24 hours before the color coats go on. My plan is to paint Frodo dark hunter green on top, and off white on the bottom. Interior will be dark hunter green will dark blue upholstery. (Hey, I like it! ) The inner panel that sits immediately in front of the 4 smaller gauges has already been painted dark Ford blue. The cluster panel itself will be dark hunter green.
Yes, I'm using Rustoleum spray bombs. Too many wolves at the door right now to invest in an air compressor and paint gun.
New use for a stepladder
- flyboy2610
Red Green
you'd better be right.
Red Green
- Mancar1
- Location: USS Gramps Garage (DD-727) Tehama County, Northern Ca.
Re: New use for a stepladder
And we all thought it was to climb on. They work well for a temp fence section also. Kind of like a air compressor, has many uses.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
I do the same thing with my cherry picker!
""Never shoot a large caliber man with a small caliber bullet."
2017 Ford Raptor
1948 Willys CJ2A w/ Ford Flathead V-8
1975 Ford Bronco
2017 Ford Raptor
1975 Ford Bronco
Spray cans are easier to clean up after than paint guns...
I have a tone of nails driven in the trusses on my garage. Lot of hanging spots for paint to dry.
- flyboy2610
I like that idea, except.... no garage.Ranchero50 wrote:Spray cans are easier to clean up after than paint guns...
Maybe someday.
Red Green
Red Green
