Seat Upolstry
Seat Upolstry
I need to order new vinyl for my bench seat and am not sure how much to order. Does anyone know how much to get?
- jimmy828
Re: Seat Upolstry
Are you talking about a prefabricated seat or are you going to stitch the cover yourself ? Here is a prefabricated replacement cover i installed myself. Before i installed the new cover i repaired the broken springs,replaced the matting,foam and webbing.
Re: Seat Upolstry
That looks great, but I am buying the material and getting it done by a shop.
Re: Seat Upolstry
That looks great! Where did you get the cover and parts?jimmy828 wrote:Are you talking about a prefabricated seat or are you going to stitch the cover yourself ? Here is a prefabricated replacement cover i installed myself. Before i installed the new cover i repaired the broken springs,replaced the matting,foam and webbing.
Re: Seat Upolstry
Wouldn't the upholstery shop know how much to order? I would think they might even get better deal on the materials?
I went to my upholstery shop, handed him my seat and pointed at a vinyl fabric in a book. 2 weeks later I swiped my credit card and left with a covered seat.
1972 Ford F100 SWB Styleside 300ci I6 3OTT
1965 Mustang 289 T5 4 Weel Disc Brakes
1972 Chevy Blazer 4x4 350/350
1955 Chevy Big Window SWB Stepside
Re: Seat Upolstry
Easy way would be to trace original sections (bottom panels, seat side panel, etc) on any sort of paper you can find - tracing paper being ideal. This can be done while the seat is in the truck. Then cut the pieces out and lay them on a table with at least the width of the material - usually 58". Arrange them in the most efficient way to keep the yardage down. Look a the material and make sure there is no obvious upside vs downside vs sideway that would make placing the pieces precise. Then simply measure the length and this would then be amount of material needed. Unless it's really expensive, order a little extra. Will you be adding piping along the edges?
Re: Seat Upolstry
PLEASE provide source for that prefab cover? thanks!!!!jimmy828 wrote:Are you talking about a prefabricated seat or are you going to stitch the cover yourself ? Here is a prefabricated replacement cover i installed myself. Before i installed the new cover i repaired the broken springs,replaced the matting,foam and webbing.
JESUS LOVES YOU! everyone else thinks your a jackass!
Re: Seat Upolstry
![Yeah that :yt:](./images/smilies/icon_yeahthat.gif)
__________________________________________________________________________
1969 F250 Ranger, CS : 390
Re: Seat Upolstry
That looks like the kit I just ordered from LMC ($185). Bottom went on easy, had to return the back portion due to crappy stitching, still waiting a week later.
Re: Seat Upolstry
Ok everyone - I found the exact material I needed for my truck seat from SMS. The only question I have now is about the seat back. On the back side of the seat back was it open or did it have a cover on it of some type. I can't tell as my seat was well used. It looks to me that I should have a burlap material on the back of the seat back. Or should I have nothing? Anyone know? Thanks.
Re: Seat Upolstry
Mine had nothing. AFAIK it was original.
- BobbyFord
Re: Seat Upolstry
Thanks everyone for your input. It's all been very helpful. Once I get the seat returned I'll post some pictures.
Re: Seat Upolstry
What is AFAIK?sargentrs wrote:Mine had nothing. AFAIK it was original.
