stock radio installation
Craigerf100
Post by Craigerf100 »
I've got a stock AM 68-72 radio to install In my 68. I don't care so much to get the radio working. More so I'd like to get the light working to light the display. Anyone know where I can find out how to install it. A PO has hacked up the wiring behind the radio.
Any advice would help. Thx
1964 F-100 Custom Cab Short Bed
1968 F-100 Short Bed
1967 Fairlane 500 Convertable
1967 Fairlane GT/A 289ci SOLD
1950 F-1 Original 239ci Flat Head V8 SOLD
1995 f-150 4x4 Swb 4.9L 5-speed FORSALE
My Build: :fr: http://www.fordification.com/forum/view ... &sk=t&sd=a
cole71
Re: stock radio installation
Post by cole71 »
I did the same thing, except I have a radio in the glovebox. On the radio there is a single black male plug. That should run over toward the driver side where there will be a plug with three female plugs. Here's a pic of a mustang, but basically the same plug. http://www.mustangmonthly.com/projectbu ... to_04.html
If your wiring is too butchered up you might could just tap into the cigarette lighter's light. I believe it is a small blue wire.
Craigerf100
Yeah that or tap into a wire off the light switch.
Nitekruizer
Post by Nitekruizer »
The wire for the dash lights, the light for the cigarette lighter and the light for the heater controls is a blue wire with a red stripe. It's controlled by the rheostat (dash dimmer control) in the headlight switch. I hate to cut factory wiring to make splices, but you may be able to plug into it at the cigar lighter or the heater controls if you make a little "Y" using bullet connectors. :) I hope this helps.
390 FE IN A "BUMP" / 383 WEDGE IN A 2 DOOR C-BODY / 351W IN A FULL-SIZE MERCURY / 194 CHEVY 6 IN A DUECE / 2.4 DOHC CHRYSLER IN A PLASTIC BUBBLE (Driver)
Craigerf100
K cool ill just do that. Thank you :fr:
jlb
Post by jlb »
cole71 wrote:I did the same thing, except I have a radio in the glovebox. On the radio there is a single black male plug. That should run over toward the driver side where there will be a plug with three female plugs. Here's a pic of a mustang, but basically the same plug. http://www.mustangmonthly.com/projectbu ... to_04.html
How did you mount your radio in the glove box? can you post a photo?
thanks
jb
cole71
Post by cole71 »
I made a bracket to hold the radio to the glovebox.
A piece on top and bottom to hold it. Then, I just cut a hole in
Back of the glovebox to run the wires. I also put an aux
Cable in and ran it through the ash tray to plug up iPods, etc...
Hope that helps
jlb
Post by jlb »
looks good, Thanks for sharing!
