Thanks for the information.
I appreciate it.
Brights? 1972 F100
- HIO Silver
Re: Brights? 1972 F100
Yep... LEDs typically don't provide enough resistance in the lighting circuit to actuate the flasher correctly if at all.Calfdemon wrote:I am not 100% sure on this, but I read that if you change your exterior bulbs to LEDs, then you are going to have to change out your flashers too... Its something that I am going to do down the road, so I have not studied up on it yet. When I finish assembly on my truck, I am just going to use the stock bulbs and then change them over at a later time.
- dbarker
correct, they make led flasher replacements... if you go LED in the tail, you need to go LED up front as well....
Drew
See My Gallery -http://www.fordification.com/galleries/ ... ?album=913
My Website: http://www.drewbarker.net
