I built a bracket out of 1/4" plexiglass for the dash speakers. It isnt' really the prettiest thing but should do the job. The bracket is mounted with 2 2" 1x24 machine screws with 1" nylon spacers to get it far enough below the dash to clear and nyloc nuts. I did have to drill 2 new holes to mount it. Everything else is under the seat.
what I found is that the retrosound has soooo many adjustments, it's kind of a PITA to get situated right. On the mounting brackets, you need to put them on ONLY the 2 forward screw holes to get the right radio depth. The knob shafts are almost all the way extended and come through the back of the dash tabs, through the infini bracket and then through the bezel.The retrosound "infinity" mounting brackets should get mounted to the FRONT of the stock stereo tabs.
I put sound deadener over the whole floor before installing the new floor mat. I should have not installed the sound mat all the way back as it made it really difficult to find bolt holes, install mounting screws, drill holes, etc. I'm not really sure if the bang is worth the buck on that...
I used ONLY the RCA hook ups from the Amp to the Stereo. There are a couple ways to connect between the two but the RCA is the cleanest sound it seemed like.
I mounted the bass adjust and IPOD / USB inputs in the glove compartment.
It sounds great and I'm really happy with the outcome. Yes it took me about 10 days of 30 minutes here and 30 minutes there but it was worth it.
Sorry for not doing a better job on the pictures but I spent most of my time herding my 2 and 3 year olds around the garage between 5 or 10 minutes of work at a time.
![Image](http://i30.photobucket.com/albums/c338/boylesdgolf/photo22_zps69d11724.jpg)
![Image](http://i30.photobucket.com/albums/c338/boylesdgolf/photo12_zpsa3a63d1b.jpg)
![Image](http://i30.photobucket.com/albums/c338/boylesdgolf/photo31_zps71f0a0fe.jpg)
