Dolphin gages
Mancar1
Location: USS Gramps Garage (DD-727) Tehama County, Northern Ca.
Dolphin gages
Post by Mancar1 »
Installing my dash insert with Dolphin gages in the 68 in next few days. Has anyone used them? If so any problems during install?
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Mancar1
Re: Dolphin gages
Post by Mancar1 »
Guess I am the only one that has used this set up.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
robroy
Re: Dolphin gages
Post by robroy »
Good day Mancar1,
I would have replied to this thread (or your other thread about wiring), yet my configuration's a little different. Still, we're among the semi-few members who have completely replaced their instrument clusters. Maybe skimming through my old thread on this topic would be amusing to you, at least: Could I ask for advice on attaching my Teleflex/V3 gauges?
I'd be curious to see some photos of your dash, and your custom wiring, if you feel like posting some.
Have a great weekend,
Robroy
Mancar1
Re: Dolphin gages
Post by Mancar1 »
Robroy
I will be posting a pic. Thank u for the interesting thread.
John
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
toanders
Re: Dolphin gages
Post by toanders »
I was able to do it, and I can barely spell electricity. Had to track down a few shorts during the install, but I think it turned out good.
Mancar1
Re: Dolphin gages
Post by Mancar1 »
Toanders
Does the new gas gauge work with your old sending unit?
Sent u a e mail.
Thanks.....John
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
toanders
Re: Dolphin gages
Post by toanders »
I had to put in the new sender that was sent with the gauges for the new gas gauge. It "worked" with the old sender, it just wasn't accurate.
Mancar1
Re: Dolphin gages
Post by Mancar1 »
toanders wrote:I had to put in the new sender that was sent with the gauges for the new gas gauge. It "worked" with the old sender, it just wasn't accurate.
Thank u. :thup:
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Fall_of_Olympus
Re: Dolphin gages
Post by Fall_of_Olympus »
Looks awesome!
Trokita101
Re: Dolphin gages
Post by Trokita101 »
Looks amazing by any chance did you take any pictures of the whole install process?
kmcypress
Re: Dolphin gages
Post by kmcypress »
as a folow up to this. what all was entailed with the wiring change? did you have to buy a lot of secondary guage wire, etc. to pull of the switch from a stock unit.
toanders
Re: Dolphin gages
Post by toanders »
kmcypress wrote:as a folow up to this. what all was entailed with the wiring change? did you have to buy a lot of secondary guage wire, etc. to pull of the switch from a stock unit.
I had to run a couple new wires from the ignition switch. Nothing major. Like I said, I don't know much of anything about electricity. Should have paid attention more in school.
