fordman wrote:I saw those cable clamps on ebay. They were listed for mustang. At 3.95 each maybe the same for shipping. They should work.
i got heat now. it's not functioning correctly but i have heat and defrost and it gets real hot!
these must be the ones you are talking about. this is not what i need. i need the nuts that slide onto the 3/16 size flapper arms that keep the cables attached to the flappers.
http://www.ebay.com/itm/Mustang-Heater- ... d8&vxp=mtr
today i bought some axle pushnuts for 3/16s. they didn't work. i also bought some nylon dowls. i drilled holes through the dowels with a 3/16s bit. they fit snugly onto the flapper rods and function the same way. it's ghetto rigged but works to keep the cables on the rods.
i installed the new heater core. installed the box. installed new vent hoses. i have both cables hooked up but could not get the passenger flapper to function. no matter what i do i can't get it to work.
does anyone have a picture of the cables connected to their heater box? it doesn't seem right to bend the right cable at such a severe angle between the clamp mount on the box and the flapper rod. i tried swapping the long cable with a short cable and installed it in a way so that it wasn't bent at a angle and just went in a straight line to the flapper rod and it still didn't work.
when i have the defrost switch all the way to the left heat blows out of the left dash vent. when it's all the way to the right it blows out of both dash vents. and no matter what it blows out the bottom of the box.
maybe my flapper is damaged and bent...
i cut my hands up pretty good white wrestling this project and got them covered in chalk dust to stop the bleeding. i seriously think rebuilding the top end of a engine is easier than this thing
