what is this light?
76Kroh
what is this light?
Post by 76Kroh »
screen shot windows 7
What is this light for that is above the parking brake release? Only comes on when starting the truck. Is there supposed to be a lense over it? :?
1968 f100 LB 360 4-speed manual :help:
Pat Crash
Re: what is this light?
Post by Pat Crash »
Brake Pressure Differential Valve. The light stays on if there is an issue.
I had to have mine rebuilt as it was difficult to get the light to go out after working on the brakes.
More info here: http://www.fordification.com/forum/view ... hp?t=11614
1971 Ford F100 Ranger XLT Long Bed — 360 with C6 Automatic — 9" with 3.00 Gear Ratio
76Kroh
Post by 76Kroh »
Pat Crash wrote:Brake Pressure Differential Valve. The light stays on if there is an issue.
OK good to know. Thx!
67 StylesLide
Post by 67 StylesLide »
So where is the switch?
I have seen it off but mostly mine stays on. Maybe from having disc brake conversion?
the mystery pickup:
'67 F100 Styleside Ranger 2WD
240/3spd
Forest Grove, OR
HIO Silver
Post by HIO Silver »
The light is to indicate a fault with the brake system and that the piston in the prop valve/distribution valve has defaulted to either the rear or the front brakes. The switch is threaded into the valve's body... it has a pin which usually sits in a detent of the piston. If the pistons moves too far to one side the pin rides up the piston's machined surface and completes the circuit to illuminate the light.
bluef250
Post by bluef250 »
The light is grounded by the switch on the pressure differential valve and also grounded to ignition switch on start. Otherwise the light should go on while in start and if one side of the brakes fail (when the truck was built).
66f250cs
Post by 66f250cs »
I will add to other posts; The chrome bezel with red translucent disc is missing but the shell is there. To replace, press the spring loaded assy from the back side towards rear of truck. Doing so will push the shell forward. Grab the front of the shell and twist. Install replacement bezel.
66 F250 camper special
69 F250 Explorer
85 Mustang GT with 1900 original miles
92 Festiva with 538,000 original miles
86 E350 extended WB van
Various IH & JD tractors (5)
TT & XT500 mc's (6)
BSA, Triumph's and twenty Yamaha two strokes
oafboy182
Post by oafboy182 »
I was just about to ask about this until I saw this post. The light in my truck is blue and on all the time. How do I reset it?
71 F100 Ranger XLT RWD LB 390 Auto
65 Mustang coupe 289 Auto (grandmas old car)
01 Silverado
10 Jetta TDI
08 KTM Superduke R
oafboy182
Post by oafboy182 »
Just saw the link in an above post. Hopefully I can figure it out.
01 Silverado
10 Jetta TDI
08 KTM Superduke R
