I guess this groove is the reason I am having trouble opening my door from the inside. I haven't checked it against the other side yet, but there should be no groove correct?
free upload image
Groove should not be there, right?
- 76Kroh
1968 f100 LB 360 4-speed manual
- Brokenarrow
Re: Groove should not be there, right?
Typical wear. Make a little "Z" bend (it don't take much) in the operating rod to shorten it a little and your door will pop right open.
'68 SWB f100, 401ci FE/C6, '68 Mustang fastback (restoration in progress)
2013 F150 KingRanch (ecoboost), '48 8N tractor
"Be more concerned with your character than your reputation, because your character is what you really are, while your reputation is merely what others think you are."
— John Wooden
— John Wooden
- 76Kroh
OK, I will try that, thx!Brokenarrow wrote:Typical wear. Make a little "Z" bend (it don't take much) in the operating rod to shorten it a little and your door will pop right open.
