67 windsheild wiper pivot gasket question
Water is leaking in wher the wiper pivots go through gaskets are badly deteriorated I have new gaskets in hand my question is do I use gasket sealant when installing the gaskets or do I just instal the gasket with no sealant?
Re: 67 windsheild wiper pivot gasket question
Why would you use sealant on a gasket? That is the purpose of the gasket.... to seal. I replaced mine on my 67 because they were letting water in as well. They now keep all water out as designed.
1967 F-100 4x4 custom cab.
That was the reason for my post was to find out that information thanks
