How do you install the window seal kit on a 1968 f100? I have the LMC kit, part number 49-7115. I removed the armrest, window handle, door handle and the metal access panel but stopped there. It looks like I have to drop the window, but I'm not to sure how to do that. Any tips or suggestions will be appreciated.
Thanks.
Anti Rattle or Window Seal kit Installation Question
"If the facts don't fit the theory, change the facts" Albert Einstein
- jimmy828
Re: Anti Rattle or Window Seal kit Installation Question
To get the window out you will have to remove the screws from the vent window which are 3 located on the outer edge of door frame and 1 below the vent window. You will also find a small bolt at the bottom of front window channel . Just take your fingers a follow the channel to bottom, you will find it. I found it was easier to try to install the vent window and larger window at the same time. Once you get the vent window bolts/screws loose you i think you will figure it out from there. Good luck
You may wish to look at the bottom of the window when it is fully down to see if there is a stop that can be removed so that the window goes a bit lower. You only need the window out of the way of the anti-rattle part just a bit in order to remove and reinstall the new one.
This one's on my list too.... please post a follow once installed.
71' F100 LWB Sport Custom 360 / Auto Boxwood Green
