OK I replaced the vent window seal on the driver side a long while ago (don’t remember for sure but think it is was a set from DC). The old rubber used to be hard as a rock and you couldn’t hardly move the vent at all. However, now I have an annoying whistle coming from the inside top 2 inches of the rubber when the vent window is closed. Even a light pressure from my finger stops it. The window itself closes tight so it isn’t the lock/vent handle. You cannot stop the whistle by pushing on the bottom of the vent glass, only by applying the slightest pressure to the rubber along the inside top. Also I probably need to readjust the large window because when I go to roll it down I can literally push it down with my hand easier than cranking it. It was not that way before I “fixed” it. I have not replaced the passenger side yet but it works fine and is quiet. The only other wind leak is the driver’s side vent behind the parking brake. I want to figure out one leak at a time though.
Did I screw something up when I replaced the seal or will everything sort itself out when I figure out why the window is wrong? I tried to replace all the bolts where they were according to the wear/paint marks and thought I had the vent seal right when I installed the rivets. I have tried loosening the top screws and readjusting the top/front of the assembly (not much adjustment there though). Do I need to redo the rivets?
By the way since the chrome covering was falling off the door panel trim I pulled all the chrome skin off and painted it white to match the blue and white outside paint. I used regular plastic bumper paint and it came out looking all right. I wish someone would repop the door panels.
Vent window whistle
Vent window whistle
No Brain - No Pain
71 F250 Sport Custom Camper Special
71 Ranchero Squire
70 Ranchero GT (Red w/351C 4V
70 Ranchero GT (Black w/302+)
03 Kawasaki Vulcan 750
74 Kawasaki H2 750 (Widowmaker)
75 Firebird 400
71 XKE FHC 4.2
04 XJ8 4.2
71 Ranchero Squire
75 Firebird 400
71 XKE FHC 4.2
04 XJ8 4.2
Re: Vent window whistle
When I got mine from DC several years ago they were sold as a pair and there was a left and a right. Can't remember if you could reverse them or not but is this a possibility? From memory I think the upper hinge is just a flange with a rivet being the hinge Is this loose or bent?
Mine also came as a pair. I am fairly certain they came from DC because I bought a new turn signal harness at the same time. I do not believe they can be switched because they are molded with a flat area for the window to seat against. The vent window components are all tight. Including the rivets I replaced that hold the seal in place. I have tried to loosen the screws on top to see if I could move anything but no luck. The area where it leaks is so small I have thought about using black tape as a shim between the glass and the rubber.
I still to pull the door panel and re-adjust the window so it rolls down right. Maybe after I get that set correctly the leak may also go away.
No Brain - No Pain
71 Ranchero Squire
75 Firebird 400
71 XKE FHC 4.2
04 XJ8 4.2
71 Ranchero Squire
75 Firebird 400
71 XKE FHC 4.2
04 XJ8 4.2
