when my headlights are on bright, the lights all around will flicker on and off then may stay off unless I step on the dimmer again at which point all lights return to normal function.
I replaced the dimmer switch and it still happened!
Where would I begin to track down the problem?
Thanks a bunch!
Steve
Dimmer Switch
- 72bumbee
Dimmer Switch
“To succeed in life, you need two things: ignorance and confidence.”
Mark Twain
1972 F-250 Camper Special. 360 A/T P/B AND a DANA 60 Rearend!
Former owner of dads 1967 F-100. It has gone home to the big road in the sky...
Mark Twain
- flyboy2610
Re: Dimmer Switch
Sounds like a bad ground in the dimmer switch wiring to me.
Red Green
you'd better be right.
Red Green
Re: Dimmer Switch
1967 F-100 4x4 custom cab.
Re: Dimmer Switch
That's not very nice...Busboy wrote:Sounds to me like flyboy doesn't know anything about electrical circuits. The dimmer switch circuits don't have any grounds at all. One wire comes from the headlight switch to the dimmer switch, the other two wires are for the low beams and high beams respectively. It doesn't help people with their problems to offer advice when you really don't know what your talking about.
To the OP, I'd suspect something drawing too much current when the high beams are on and the headlamp switch or something upstream not being up to the task.
Re: Dimmer Switch
Maybe not but you know that I'm absolutely right.
- eggman918
Re: Dimmer Switch
Any bad/loose connection hot or ground will cause the circuit to pull more amps than it otherwise would, an IR thermometer should show a loose/hot connection the headlight wiring looms on trucks our age are also often not up to the task any longer, the wire or connectors can deteriorate over the years and the thermometer can again tell you whats going on under the insulation....
Steve
- phantomtruck68
Re: Dimmer Switch
It's your headlight switch. They have a thermal breaker inside that will trip when to many amps are drawn through it. Have you changed headlights to halogens or added more markers, tail/brake lights to your truck. That is usually the reason of drawing to many amps. There is a person hear on this sight that makes a headlight re-wiring harness that adds relays for the high and low beams. That will drop amp draw on switch. I know from experience.
Joe
My Phantom truck
1968 F250 4x4
390 FE, bored .030, Crane 272 cam, 600cfm Edelbrock carb.
My Phantom truck
1968 F250 4x4
- 72bumbee
Re: Dimmer Switch
I will replace the light switch next, as that seems the easiest.
What concerns me is the fact that they will flicker on bright... It seems I tried jiggling the light switch to see if that would make them flicker. I also tapped the dimmer connector to see if that would make it flicker. No luck ..
I'll look around for a new harness in the meantime.
Thanks for the great input!
Steve
Steve
Mark Twain
Mark Twain
Re: Dimmer Switch
They usually only blink on high beam because high beams draw more amps, but my old snowplow truck will even blink on low beam after an hour or so.72bumbee wrote:What concerns me is the fact that they will flicker on bright... It seems I tried jiggling the light switch to see if that would make them flicker. I also tapped the dimmer connector to see if that would make it flicker. No luck ..
The relay setup will cure this (but I'm just tryin to get through this winter) (hopefully a "new" old truck next year )
