Replacing vinyls with steel
Nkreigh
Post by Nkreigh »
I am attempting to replace my vinyls with steel door panels. There are holes in the door that align with the holes in the steel door panels but the holes in the door seem to be too large? The door holes are round so it does not seem they would have a speed nut or some type of insert?
eggman918
Re: Replacing vinyls with steel
Post by eggman918 »
They are designed to accept a "clip" that fits the screws that hold the panels in.
Steve
Nkreigh
Post by Nkreigh »
Thanks, great.
You do not by any chance know where I can find the clips?
I have tried LMC NPD.
eggman918
Post by eggman918 »
When i lived in Bakersfield CA. there was a shop that specialized in fasteners and they carried that sort of thing......you might try an 'old school' hardware store they might have them if not the bone yard is your best bet.
If you cant find them locally let me know how many you need and i will pick them up on our next trip to the bone yard there are usally bumps and dents there :thup:
Steve
Nkreigh
Post by Nkreigh »
Wow!
Thanks for the offer, I will look first.
69Ford
Post by 69Ford »
I think part number 12 is the correct part although this is a different door. They did not show this part on our door not 100% sure. At 2$ apiece plus shipping and at least 15 per door kinda spendy for these fasteners. http://www.lmctruck.com/icatalog/fb/full.aspx?Page=18
Canonman67
Post by Canonman67 »
Also check Ebay for u-nuts.
HIO Silver
Post by HIO Silver »
Head down to your local Autozone and hit up the fastener trees for "speed nuts", "U-clips, or "J-clips". You'll need to measure the distance from the edge of the flange to the hole.....
Or visit http://www.clipsandfasteners.com
http://www.clipsandfasteners.com/Nuts_U_s/115.htm
http://www.clipsandfasteners.com/Nuts_J_s/114.htm
