Ok, so not exactly asking for anyone to identify this part, but there is something wrong with this. Can anyone figure it out?
...and yes, I already know the answer.
Can you guess it?
Can you guess it?
1953 F100 (Waitint for attention)
1969 F100 LWB w/ 72 grille (Daily driver & work truck)
1969 F100 LWB Parts truck
1971 F100 SSWB 4x4 (Current Project)
2016 Jeep Wrangler Unlimited Sport (Actually the wife's)
Re: Can you guess it?
needs to be re-clocked.
1968 Highboy
1976 Highboy
1969 F250 Camper Special
1941 Dodge Power Wagon
1930 Model A Coupe (Hotrod)
VW Sandrails
Honda ATC's
1976 Highboy
VW Sandrails
Honda ATC's
- flyboy2610
Yepper.Bill Ramsey wrote:needs to be re-clocked.
Red Green
you'd better be right.
Red Green
- BobbyFord
Looks like it was assembled on a Monday morning.
Gold Stars! When I went to put it back on after cleaning it was pretty obvious. You gentlemen have sharp eyes... ...or you may have done that one before too
it a fuel pump for a 390 ford with the screw on filter-it seperates the water if any and the gas-so you dont get water in the carb
no bolt holes to bolt it on to block
- hot-rod
Put it in your Bump and you save gas
- HIO Silver
It's a mechanical fuel transfer pump.. the port is pointing to the right and made for the 351A, a highly modified Cleveland/Windsor hyrbid engine developed specifically for the RH Australian F-series trucks. That's why the engines have an "A". The pump body is made of powdered titanium and formed under extreme pressure.
A little known fact is that the part was also used in the Apollo space program of the 1970s.
