67 light switch
jzjames
67 light switch
Post by jzjames »
Its a one-year only switch I believe.
Can these switches be repaired by me? Cleaned/fixed etc.?
Ive lost the interior light (above rear window) and the dimmer part of the dash lights. In fact the dash lights wont come on anymore. I think this is because the light switch with its dimmer device is messed up, right?
Can they be opened up and repaired? Thanks for any tips.
hot-rod
Re: 67 light switch
Post by hot-rod »
Why do you think it´s a "one-year only switch"? What is different to the normal one?? In my opinion the switch from 1965 to 72 is the same. Can you show pics??
jzjames
Re: 67 light switch
Post by jzjames »
the 67 light switch has a different connector on the back side of it from the 68-72 if I'm not mistaken.
You can rig the later switch onto it, but it's different.
jzjames
Re: 67 light switch
Post by jzjames »
I'll have to :thup: see if I can take apart, and let you know.
