1970 f250 camper special
lloyd70cs
Re: 1970 f250 camper special
Post by lloyd70cs »
You may laugh at how i did it. After trying coca cola to no avail i soaked them in apple cider vinegar for a week. Worked great. But not trying to fool anyone. Their painted over.
Also new wheels and rims.
daveford72
Post by daveford72 »
lloyd70cs wrote:You may laugh at how i did it. After trying coca cola to no avail i soaked them in apple cider vinegar for a week. Worked great. But not trying to fool anyone. Their painted over.
Looks good so far.BTW why did you not keep those KILLER split rims! :lol: They are a pain it there tight :doh: Good luck with your build
ddcrim
Post by ddcrim »
Just a suggestion, but when you get it back together I would remove the plugs and spin the motor with the starter and
be sure your getting a good supply of oil to the rockers.
ThinLizzy13
Post by ThinLizzy13 »
Well either way they look like they cleaned up real nice!
'63 F100 Uni 223 3OT
'67 F250 CS 352 4Spd
lloyd70cs
Post by lloyd70cs »
Well I'm running again without smoke and sounding pretty good. Next step is to make a home made throttle linkage as the stock one is sloppy and sticky at the same time. Saw a home made kit over on ford-truck.com . Anybody done this before?
Ranchero50
Post by Ranchero50 »
What did you end up doing to the head and what did you find?
The stock trapeze carb linkage is pretty clever and worth making work correctly. It actually makes the throttle opening linear and smoother vs. a simple rod. Per other options, pull one off a later model dentside.
lloyd70cs
Post by lloyd70cs »
Yeah i didn't remove the heads. Just the intake manifold. Things are running smooth for now.
lloyd70cs
Post by lloyd70cs »
I was driving home tonight and felt/heard a rattle from the back end. I had in mind that when i bought the truck in January the PO had the cab on but not bolted. I bought the bolts back then and got them all on except the one above the rear fuel tank but more recently realized i probably hadn't tightened them enough. Indeed they were a bit loose. After tightening them i tried moving the bed, seemed good. Then i tried the cab and THAT seemed to move more. Checked the cab mounts. Check them out.
Drivers Side
Passenger Side
The passenger side had some give to it, the drivers side seems better. Also, there is a hole through on the passenger floor board.
Just wondering what is involved in repairing these? Do i have to remove the cab, which means removing the engine etc? I hadn't intended to chase rust on this thing but this seems a bit problematic.
lloyd70cs
Post by lloyd70cs »
Hi everyone. Well I got started on fighting the rust. I contemplated buying a welder and learning but looking back I'm glad I got someone to do it that new what he was doing. I'm attacking it in parts as I don't have the money to do it all. But I managed to deal with the whole passenger side. New cab mount door pillar and floor pan as well as patches on the inner wheel well and some other spots.
Been excited to get this done because now I can put in the new carpet and upholstery that's been sitting in the garage. I also am not loosing little bits out the hole i had in the floor/side of the cab and not freezing from the air coming in.
Ranchero50
Good deal. Surprisingly, the crappy heater in these trucks will run you out when the cab is sealed up right.
lloyd70cs
Post by lloyd70cs »
I'm also painting some spare parts to see if I want to paint the truck. This was done with a rattle can. I'll probably do the whole thing in the summer.
lloyd70cs
Post by lloyd70cs »
One thing I had heard about when getting welding done was to get parts from DC as other guys were not good fit etc. Well of course I ignored sound wisdom and went for the cheaper option. So don't do that by the way. :doh: the cheaper floor pan and door pillar were not the right fit so the time the welder took reshaping them more than made up for the difference in cost to buy the better product. Why don't I learn!! :cry:
It's a guy thing. :D
Lone Ranger
Post by Lone Ranger »
That looks great for a rattle can! I don't know why more people don't do that. Cans nowadays spray real nice and lay flat too. I did the whole interior of my last truck with cans and it looked like a pro did it!
Kyle
lloyd70cs
Post by lloyd70cs »
Yeah. I hope to be able to do a decent job without spending a fortune. That piece had etching primer, then three coats of white. Only one of blue (not finished yet). Some parts of the truck will need rust converter.
