1967 F-100 project
Re: 1967 F-100 project
Great score. :thup:
Dylan68
Post by Dylan68 »
67nukeford wrote:Weather held out long enough for me to get some POR-15 on the cowl and floor. Plan on shooting epoxy over it, and I'll probably puff can some black paint over the cowl section, before I weld it back together.
Great job on the depth of this restore! I plan on doing the same here shortly.
Dylan68
Post by Dylan68 »
Great work so far on the build. Your attention to detail is amazing and it will pay dividends for years to come after the project is complete.
C7TZ
Post by C7TZ »
Great write up, what fuel tank are you using?
Manny
Post by Manny »
You know i watched this one a while back like a hawk. I failed in not keeping up. Very impressive work on the cab and body and paint. Truly a better cab than for ever built!!! Looking forward to more!!! :thup:
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
Busboy
Post by Busboy »
67nukeford wrote:Thanks, starting to look like a truck again! Hood parts coming together. Lets start with the pretties....Hood hinges plated in zinc. Only 25 a piece to get these plated.
Those hinges look awesome, where did you get them done?
1967 F-100 4x4 custom cab.
basketcase0302
Post by basketcase0302 »
Looking sweet! :pop:
Love how the hood results of stripping / the plating / and the cargo lamp switch (very nice "finishing touch"). :thup:
67nukeford
Post by 67nukeford »
Man, been a while since I've updated this! So, I'll see if I can get this up to date, and stay on it!
Pat 1967 F100 4WD
LINK TO PROJECT THREAD
:http://www.fordification.com/forum/view ... &sk=t&sd=a
Good to see you back.
So have you thawed out yet?
67nukeford
Well, so much for staying up to date on this! So, time to catch up! So, allow me to try and get caught up! Man, can't believe how far behind I am! So, box sides came off, and the box went off to sandblasting. Had to drill a bazillion spot welds, and actually cut the back of the box side off, since its spot welded internally.
Pat 1967 F100 4WD
67nukeford
This is the box, back from the sandblaster. I also sent the box sides, and, a section from my old bed, to use as patch panels, there are several sections needing patches on this box.
Pat 1967 F100 4WD
Wow, looks like you have been busy!
67nukeford
Yeah, and that is from 2 years ago! I've got a bit of catching up to do!
Pat 1967 F100 4WD
67nukeford
a few more pics
Pat 1967 F100 4WD
