Its been a while since I've posted. I've been driving around enjoying the truck (F250 2wd Camper Special) without any updates besides a new rag joint and its first wash and wax since like 1972.
I'm getting ready however to take it off the road this summer for a bit and get some things done. Here is a list of things I want to address
1. I would like to do some paint, at least deal with the rust underneath. Frame and cab underside. I had the cab mounts and floor pans done last year.
2. The clutch pedal is slow to return after engaging it, may need some work.
3. I have done a bunch of reading on this site on brakes and if I'm not mistaken, the 1970 F250 2wd front spindles were the same for both drum and disc. So will be doing that swap. I have a full front end from a 1979 including proportioning valve, pre-bent lines, i-beams, etc so I can always do the full swap if the spindle is indeed different. Its already got a power booster and what I believe is a disc/drum MC (smaller bowl at rear of MC)
4. Also on the 1979 front end I have the power steering box, pump, bracket, lines, pitman arm and linkage. I am going to tackle that too. I can't remember which box fits without chopping the steering column/shaft but will address that too, lots of information on here to help,
![FORDification Rocks! :fr:](./images/smilies/icon_FORDification.gif)
If it comes to chopping shaft and welding back together I will have a shop do that. It not something I trust myself with.
5. I have interior finishing stuff like new upholstery etc to clean up the cab with.
I was also thinking of these items:
Electronic Ignition
Convert the 360 to 390?
Sanderson Shorty Headers and dual exhaust
Removing the underside gas tank
Any advice on these I would greatly appreciate. The bigger questions are:
Am I right about the spindles for the F250?
The 1979 front disc setup is single piston but I can only find 1970 and 1979 parts diagrams with dual piston setup??
Happy Spring Everyone!
Lloyd
