Painting 390 valve covers
jingo
Post by jingo »
The PO installed chrome valve covers, they looked like junk when I got them, worse now with rust and pit. Fortunately I have a pair of 'powered by ford' originals, which I've media blasted, they're clean. Question is how to recoat them in Ford blue? What primer, paint, will last, any tricks to making them look like new. Thanks!
1970 Ranger Styleside, LWB, Harbor Blue
416, C6, man brakes & steering
Re: Painting 390 valve covers
The mustang guys have done pages on the correct paint color.
As for paint itself I had real good luck with POR15 engine enamel.
jzjames
Post by jzjames »
I DIDNT use primer on my cleaned valve cover (strait six) and painted with Duplicolor brand engine enamel. I swear by that stuff, but think the primer is counterproductive when using engine enamel.
For my 67, Old Ford Blue was the correct color. Then there is ‘Ford Blue’ also which is used on some years I think.
Ohiotinkerer
Post by Ohiotinkerer »
No primer.......I wash mine down with acetone before painting to make sure they're clean and I've used this paint with good results..........
https://www.ebay.com/itm/1966-81-Corpor ... l2649#rwid
"Life is a garden - dig it"........... :thup:
1997 Honda CBR 900RR
timachone
Post by timachone »
+2 on using no primer... I think they were paintend without from the factory.
I cleaned them up with a soft grinding wheel on a drill machine and softening the result with some fine and soft grinding pads. Then brake cleaner, air pressure and then the paint. I used VHT engine enamel out of a spray can with great success on the whole engine
Tim :drive:
1970 Ford F250 360 FE 2V C6
1973 Ford Mustang Mach 1 351C 4V 4-speed
2012 Ford S-Max 2.0 EB AT
2017 Skoda Fabia Monte Carlo MT
jingo
Post by jingo »
Thanks all, just what I was looking for (as always)!!!
:fr:
geradr4
Post by geradr4 »
Any decent engine enamel paint should do the trick.
