The Bandits 72
- The Bandit
Re: The Bandits 72
Thought I would post a little comparison photo to show the difference in the wiring harness after it's all thinned out.
I'm hoping to hook it all back up and see if the motor spins over or not tomorrow.
Now I need to turn my attention to the rear mounts for the lower control arms on the front.
"Don't believe everything you see and read on the internet." Abe Lincoln
1972 F100 custom SWB 302/C4 Auto PS No AC Wimbledon white and rusty..
Re: The Bandits 72
You're the man - I'm not brave enough to tackle that - wiring has ever been a good experience for me.......
What are you doing for your control arm mounts? I ordered a set of these......
https://www.outcastautoworks.com/produc ... arm-mounts
I was going to go with the weld on plates until I saw these - you'll have to call Kyle and leave a message and he will call you back to order them since they are on backorder but I haven't heard a bad thing about them - it's about a 3 week wait for them is the only drawback if you need them now and he will be upfront with you on that!
Also meant to ask you what thickness plate did you use to box the frame for the CV swap?
![Surprised :eek:](./images/smilies/icon_eek.gif)
1997 Honda CBR 900RR
- The Bandit
Re: The Bandits 72
I used 3/16in steel to box in the frame up front and probably went a little over board with ow far i boxed it in but it's what I wanted.
I'm sure it works and I almost settled on doing the plates but I really didn't want to cut and rotate the bushing in it's sleeve and then weld it back and have that much heat so close to the rubber bushing.
Thanks for posting those I haven't seen those yet. Is that price for the pair or each? I have started on my own little setup and it's really not to far off from what he has there.
I'm going to check with a guy I know and see if he will cut these on his plasma table out of 1/4in steel.
Re: The Bandits 72
That's the price per pair on them - I thought about making my own also since the weld/fab dept foreman is a friend of mine and makes me anything I need on the laser we have but I'm not gonna be putting my CV front in for a while so I decided to go with theirs that way I wasnt having to find someone to do them when I'm ready to do it........
- The Bandit
Re: The Bandits 72
I got to speak with Kyle for a bit the other day and he is getting ready to make a move to another state and is trying to complete the orders he has and didn't really want to take on anymore right now because he wasn't to sure when he could fill the order by but was more than happy to let me pick his brain on why he did his the way he did them. Super nice guy!! If and when I do another truck like this I will certainly be hitting him up for the parts that I need to get it completed but for now I will proceed with making my own.Ohiotinkerer wrote:That's the price per pair on them - I thought about making my own also since the weld/fab dept foreman is a friend of mine and makes me anything I need on the laser we have but I'm not gonna be putting my CV front in for a while so I decided to go with theirs that way I wasnt having to find someone to do them when I'm ready to do it........
I decided to just cut these out the hard way myself yesterday with my angle grinder with a cutoff wheel and a hole saw in my drill press and then start piecing them together. Only took me a couple hours to get this far with both of them so it wasn't bad at all.
Think I will finish up welding them today and get the holes drilled in them to mount them in place. Next on the list is either finding bushings to fit or just making my own for them.
Re: The Bandits 72
Those look really good - really close to the ones I bought! I just got the postal notification that mine are on the way so I should have them by the end of the week.......
.......on your bushings you could do like I did for my inner control arm bushings on the TBird IRS and get some Delrin round stock and turn and sleeve them - it machines out really nice and saved me some major $$$$$........there's a pic of them on my project thread...... ![Wink :wink:](./images/smilies/icon_wink.gif)
And you're right about Kyle......super nice guy......![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
Re: The Bandits 72
Very impressive freehand work Bandit!
- The Bandit
Re: The Bandits 72
Thank you sir! I must admit though I cheated a bit.. I cut out test pieces from some 1/4in plywood I had here with my cnc wood router and then glued them together and tested them first. Prototype I guess you could say.hfdco4 wrote:Very impressive freehand work Bandit!
With all the time I've had in the wiring harness deleting this and tracing this wire back to see what it went to and reading and following diagrams to see what wire does what it ALL paid off to night!! I've been working on wiring in the original switch from my truck so I could use it to start the truck and got everything plugged back in to all components and decided to drag the crown vic fuel tank back it to see if the fuel pump would prime and with the first turn of the switch I got to hear that awesome sound. I had a running fuel pump ready to prime something. Also with that try I heard all kinds of electronics starting up and the throttle blade centering its self so I hooked up the pedal to it and sure enough it works as well!!
Next I decided to see if I could get it to spin the motor over so one the very first try.............nothing happened...
![Hmmm :hmm:](./images/smilies/icon_hm.gif)
Oh wait a minute I said is the trans in park or neutral??? and it was... well shoot.
Must have been some fuel sitting if the fuel lines as there are no fuel lines what so ever hooked to anything...
Anyway long story short IT WILL RUN!!! and that gives me motivation to get moving on this project!
Re: The Bandits 72
Impressive! Congratulations!
Re: The Bandits 72
![Yeah that :yt:](./images/smilies/icon_yeahthat.gif)
![Woohoo! :woohoo:](./images/smilies/icon_woohoo.gif)
- The Bandit
Re: The Bandits 72
Great Idea on the delrin round stock! I read that over in your thread about using the round stock and managed to find some that is 2" and have it coming to me now. It should be here tomorrow sometime and then I can get to work on that next and be done with this little project.Ohiotinkerer wrote:Those look really good - really close to the ones I bought! I just got the postal notification that mine are on the way so I should have them by the end of the week..............on your bushings you could do like I did for my inner control arm bushings on the TBird IRS and get some Delrin round stock and turn and sleeve them - it machines out really nice and saved me some major $$$$$........there's a pic of them on my project thread......
- The Bandit
Re: The Bandits 72
Finally got the delrin round stock material in for my control arm bushings so I could get them made. But seeing now I do not have access to a lathe to turn these down I decide to see if I could make them with my cnc router I use for some wood working projects. I use Fusion 360 for all my cad things and to write the Gcode for the router so it's pretty easy to come up with something simple to do this. I put on my cheap router and holder and loaded the code in to the cnc program and let it work. I had it bore the center hole first and then had it set up like a tool change so I could remove the clamps and fastened the part down through the center hole so it could machine the outside.
Here are my results. I think they will work just fine.
Re: The Bandits 72
Nice job on them.....
.......router was good alternative way of doing them! One thing on the delrin is you'll have to grease them or they might squeak some - I'll let you know what to use on them as soon as I remember what I did with the paper i had it written down on............ ![Doh :doh:](./images/smilies/icon_doh.gif)
- The Bandit
Re: The Bandits 72
I try to always make use of what I have on hand and it gets me by most of the time.Ohiotinkerer wrote:Nice job on them............router was good alternative way of doing them! One thing on the delrin is you'll have to grease them or they might squeak some - I'll let you know what to use on them as soon as I remember what I did with the paper i had it written down on............
Thanks for the heads up on the possible squeaking as it would have driven my crazy looking for it for sure. I have a ton of the grease that you get when you buy the poly bushings for like my mustang I betting that would be a great grease to use on these.
I got to work on the truck today some and was able to get them all welded up and test fitted on the frame now to just finish up with drilling all of the mounting holes for them. I'll have pictures of them probably on monday installed on the frame.
Thursday I finally tracked down a fuel tank that I'm going to use in the back of the frame and ordered it. It and the sending unit and the fuel pump assembly will be here on monday so I should be able to test fit it i. the frame rails.
Re: The Bandits 72
Very resourceful of yourself!
