T18 input shaft
T18 input shaft
I have a 1973 T18. I have read that the end of the input shaft has a .668" diameter. Mine measures .668" on the end and at the base at the splines. Everything else in between has from .010" to .020" of wear. What is an acceptable amount of wear on this piece? And whether or not it should be replaced.
