![Yeah that :yt:](./images/smilies/icon_yeahthat.gif)
Power Steering Box
Re: Power Steering Box
Thanks for the suggestion.
Here is what I have found.
Cardone 277504 for Walmart $137.69 Free shipping. No core mentioned.
Redhead $286 + 150 core (additional to ship)
Redhead is 18:1 What is the factory ratio?
I don’t mind spending the extra, but is it worth it?
What is better about Redhead?
FYI. My 1970 will have FordPerformance 302.
Front disc brakes from a 1976 F100. Lowered with Dream beams.
Summit has that Cardone
https://www.summitracing.com/parts/aaz-27-7504
They are a volume remanufacturer, I would consider them an absolute last resort...
Are you referring to Cardone as last resort?
YesF100 Hillbilly wrote:Are you referring to Cardone as last resort?
Here are a few quotes from people that have bought Redhead: "If they are selling you a Napa or O'Reilly's box, save your money. Most likely their rebuilt boxes will have a worn out shaft that comes out of the bottom of the box and neither of those companies rebushF100 Hillbilly wrote:Thanks for the suggestion.
that shaft, but RedHead Steering does. RedHead boxes costs more, but the others are usually worse than your original. Then I found out about RedHead Steering, who are the only ones that bore the casting and bushes it for that
shaft. I ordered a box from them; no more slop."
"If you need a new steering box, contact Red-Head Steering out of WA state... they're all the rage. Avoid local parts store steering gears...
all they do is change the seals and do a minor adjustment. Redhead will replace worn parts and rebuild it better than new. About $360 for a PS gear."
I looked at the Redhead, but also found Blue top which is a cousin to Redhead. Talked to Blue Top owner Ryan. (really nice guy)
From the reviews Redhead has begun some outsource machining that has compromised quality. Blue Top is all down in house with a 1 day turnaround.
From what I have read, Ford machined the sector shaft right into the cast iron housing. The shaft wears the race into an egg shape. Most rebuilds don't replace the race. Red Head & Blue Top install an actual bearing race that eliminates slop. That is why they are so expensive. I will probably go with Blue Top.
- sparky72
I bought and installed a Red-Head around three or four months ago. I bought 2751; it was $285 plus the core. It's nice and tight. I looked at Blue Top as well but they were a bit more expensive, so I went with Red-Head.
Taylor
1972 F250 Ranger XLT 2wd / 8100 GVW / 390 / T18 / 3.73 D60
never mind found tech article
Not real sure where you read that info from but from the proverbial "horses mouth" I'll say it's wrong."F100 Hillbilly"I looked at the Redhead, but also found Blue top which is a cousin to Redhead. Talked to Blue Top owner Ryan. (really nice guy)
I've owned no less than 10 Ford power steering boxes from the bump and dent era that I had on running driving trucks, (with prob 6 of those leaking from around the sector shaft on the bottom-the chronic failure point of why 95% of the boxes warrant replacement).
Every single box I tore down, (I had to rebuild my 76' Early Bronco back in the early 80's with a kit due to the cost and no availibility of a box back then) the sector shaft itself becomes "scored"/worn down where it meets the lower bearing bearing.
Fact remains that if the sector shaft is worn or scored you can throw new races and bearings in it every day of the week and it will always leak until you replace the sector shaft itself, (ask me how i know this...).
![Banging head on the wall :hw:](./images/smilies/icon_headwall.gif)
I'd gladly pay Redhead's or Blue Top's prices for the warranty/guarantee folks.
![2 cents :2cents:](./images/smilies/icon_2cents.gif)
