Basketcase#16-once in a lifetime build-now gone. :-(
Re: Basketcase#16-once in a lifetime build-now gone. :-(
Keep your head up buddy!
JeffCobb1956
Post by JeffCobb1956 »
Could you send me detail of how you did the 73-79 brake pedal switch to the 68-72 F100. Thanks again :D
basketcase0302
Post by basketcase0302 »
"JeffCobb1956"Could you send me detail of how you did the 73-79 brake pedal switch to the 68-72 F100. Thanks again :D
If you PM me an email address I can send a few very good descriptive pics, (as well as the info needed on how to do this).
Doesn't do much good without the pics, (and we're not allowed to post an email address here on the forum as it draws spam bots).
I'll never forgive photobomb for what they did to our "hobby" here as I took 7-8 years to write and document a very detailed build on BC #16.
And they basically destroyed all that work with one greedy money making decision.
:cuss: :cuss: :cuss: :cuss: :cuss: :cuss: :cuss: :cuss: :cuss: :cuss: :cuss: :cuss: :cuss: :cuss: :cuss: :cuss: :cuss: :cuss: :cuss: :cuss: :cuss:
JeffCobb1956
Hi 67-72 F100 Friend! If you dont mind maybe you cand help me. I recently purchased a Kwikwire universal 20 circuit harness thinking it was very BUMP friendly. I need some help to get over my first stumbling block, The Emergency and Turn signal flasher systems since they are located at-on the Fuse Panel. Thanks to fordification's diagrams I understand how my 68's Emergency Flasher and Turn Signal systems are wired and works.
I would be greatly appreciative if you could provide me with some info or a thread or another site or if you could explain how these 2 circuits work and are wired in from those universal fuse panels?
Thanks in advance
Jeff1956
basketcase0302
="JeffCobb1956"Hi 67-72 F100 Friend! If you dont mind maybe you cand help me. I recently purchased a Kwikwire universal 20 circuit harness thinking it was very BUMP friendly. I need some help to get over my first stumbling block, The Emergency and Turn signal flasher systems since they are located at-on the Fuse Panel. Thanks to fordification's diagrams I understand how my 68's Emergency Flasher and Turn Signal systems are wired and works.
Thanks in advance
Jeff1956
Afraid I'm not gonna be able to help much with a proprietary wiring harness.
You'll probably have to contact the folks there at Kwickwire on how to graft it into the original harness.
JeffCobb1956
Hey! Thanks for getting bacj, I haven't call them yet. I give them a call. From reading ther instructions they seen to cater to the 73-79 F series. Byt i did grab a 70-75 F series harness from my pick & pull. The hasard sw is wired the same. Plus i dlownloaded Painless 21 circuit harness which seams to get me closer. Thanks again.
