68 f100 restoration.
Fordkid68
Re: 68 f100 restoration.
Post by Fordkid68 »
Thanks Jimmy!!
Adam
My first truck,
^^Build Thread^^
(no other projects, YET!)
Venomous duck
Post by Venomous duck »
You are making some great progress. I may be able to offer some insight on those two holes in the firewall. They are for a dealer added a/c. The large hole is for the low pressure hose and the smaller is the high pressure hose. The need to be large so the fittings will fit through the firewall to connect to the evaporator hanging from the dash. It would have had grommets to protect the hoses and some dum dum to seal the hole. I am aware of this because my truck has the same thing and was untouched before I tore it down. You can probably see what I am talking about if you look back at my project update. Your doing nice work.
Fordkid68
Post by Fordkid68 »
Thank you Duck!! I was wondering what the holes were for. now I know!
Adam
My first truck,
^^Build Thread^^
Fordkid68
Post by Fordkid68 »
After a busy couple of weeks, I was finally able to spend some time in the garage.
Started stripping paint in the cab with flap discs, so I can paint the floors, and firewall, black.
Also painted the rear shocks.
Adam
My first truck,
^^Build Thread^^
Fordkid68
Post by Fordkid68 »
Here are the freshly painted shocks installed.
I also got some small holes in the rad support welded up. I had started working on it months ago, and started concentrating on the rest of the truck, and forgot about it! So now I am going to finish it.
Adam
My first truck,
^^Build Thread^^
Sometimes it's hard to keep up on everything. Looks like you are making progress though.
67mann
Post by 67mann »
hfdco4 wrote:Sometimes it's hard to keep up on everything. Looks like you are making progress though.
:yt: It's real easy to get side tracked.... take your time, document what's been done and needs to be done :thup: Your doing a bang up job though 8)
Fordkid68
Post by Fordkid68 »
Thanks guys, I really appreciate it!
Adam
My first truck,
^^Build Thread^^
cumminskiller
Post by cumminskiller »
Lookin good! You gonna reach your goal?
1967 Ford F100 Ranger 2WD Shortbed = Playtoy
2002 Ford F250 Powerstroke 6 speed = Towpig
2017 Ford Fiesta ST = Daily
Fordkid68
Post by Fordkid68 »
cumminskiller wrote:Lookin good! You gonna reach your goal?
Thanks! I'm hoping to have it done, but I don't think the engine will be done in time.
Adam
My first truck,
^^Build Thread^^
Fordkid68
Post by Fordkid68 »
I have still been making slow progress, but I guess any progress is good progress!
Got some small block engine-perches. Started cleaning them up and it made a huge difference!
Next, I started working on the heater controls.
This is how it started.
I got the whole thing torn apart. As you can see it was pretty dirty.
Adam
My first truck,
^^Build Thread^^
Fordkid68
Post by Fordkid68 »
Here are all the main parts cleaned up.
The face is actually all chrome, that was just painted over black. I don't know if I should leave it chrome, or paint it how it was originally?
Adam
My first truck,
^^Build Thread^^
miller
Post by miller »
Looking good Adam. I think it looks good black especially with new coat.
Troy
JWW
Post by JWW »
:pop: Nice thread. Truck is coming along nicely.
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
hdman90
Post by hdman90 »
It's been awhile since I've checked on your progress! You're cruising right along! Keep up the forward momentum!!!
