Forest Service Truck Coyote Swap
miller
Re: Forest Service Truck Coyote Swap
Post by miller »
Thanks! I welded in driver front cab mount. Started on passenger front lower door post repair. For some reason I thought this side would be less work, but now that it is opened up its going to be more. Sick of rust time for a break!
Fordkid68
Post by Fordkid68 »
Looks great, Just think soon the rust will be all gone, and you'll never have to worry about it again!
Keep it up.
Adam
My first truck,
^^Build Thread^^
(no other projects, YET!)
miller
Post by miller »
Thanks Adam. It needs to be done, but looking forward to doing the stuff that makes it go fast adding a supercharger or twin turbos!!!
miller
Post by miller »
Removed front cab mount and opened everything up.
miller
Post by miller »
Fabbed up lower rocker and inner kick panel.
miller wrote:Fabbed up lower rocker and inner kick panel.
Wow, fantastic work!
cumminskiller
Post by cumminskiller »
miller wrote:Thanks Adam. It needs to be done, but looking forward to doing the stuff that makes it go fast adding a supercharger or twin turbos!!!
I vote TURBO'S!!!
1967 Ford F100 Ranger 2WD Shortbed = Playtoy
2002 Ford F250 Powerstroke 6 speed = Towpig
2017 Ford Fiesta ST = Daily
Fordkid68
Post by Fordkid68 »
I vote TWIN-TURBOs, and a SUPERCHARGER!!!
Adam
My first truck,
^^Build Thread^^
miller
Post by miller »
Now thing are getting exciting!
jimmy828
Post by jimmy828 »
Heavy duty work. Looks good :thup: By the way, when do you sleep? :D
miller
Post by miller »
Summer is coming so things will probably slow down. I’ m a bit tired of this cab and metal work so just trying to get it done and back on the frame!
miller
Post by miller »
Tac welded lower rocker panel in. Cleaned up inside front post with wire wheel and applied eastwood frame coating. Fit rocker to door post piece. Should be able to start assembly in next couple of days.
miller
Post by miller »
The passenger pan is in ok shape but for some reason I feel like I should replace the hole thing? All that clean metal from a new pan is enticing. Any thoughts?
Really impressive work. Keep plugging along you are making great progress!
