Forest Service Truck Coyote Swap
miller
Re: Forest Service Truck Coyote Swap
Post by miller »
I just need to finish the inner cab corners, but the rust is removed for now. I'm guessing it will hold together for another 50 years. The drivers door has some and the rear bed under the tail light, but that is part of the patina! I'm saving those to remind myself how enjoyable rust repairs are and stay off ebay! LOL
miller
Post by miller »
Another full day to fab these little pieces. Not really sure if thats how it was originally, but it will work for this truck.
miller
Post by miller »
Same for drivers side. Seam sealed inner welds and sprayed some weld through primer.
miller
Post by miller »
Getting busy now that its summer here in Wisconsin. It is so damn short you better do a few things or its back to winter before you know it. I got the inner cab corner panels welded in. Need to clean up bottom of truck and paint it next.
Really good work on making poor quality parts fit.
Fordkid68
Post by Fordkid68 »
Awesome work!! Looks great!
Adam
My first truck,
^^Build Thread^^
(no other projects, YET!)
miller
Post by miller »
I got body work all finished up. I cleaned, sanded and epoxy primed bottom of truck. Next seam seal, 2K primer and topcoat.
miller
Post by miller »
Two coats 2K primer and two coats top coat forest service green.
Fordkid68
Post by Fordkid68 »
AWESOME!!!! Looks great!
Adam
My first truck,
^^Build Thread^^
miller
Post by miller »
Finished painting. The exterior still needs a Mat clear coat at some point. Started installing gas tank. Cut lower frame rails and moved cross member to the rear. I am going to hang the tank with stainless steel straps so it can be serviced without pulling bed.
miller
Post by miller »
Cleaned, prepped and painted remaining part of frame. Installed cab which is some welcome progress. Need to install front clip and bed to get everything aligned to drill front cab mount holes.
Fordkid68
Post by Fordkid68 »
Amazing work! It must feel great to start putting things together after all that metalwork!
Adam
My first truck,
^^Build Thread^^
miller
Post by miller »
Thanks Adam!!
Great progress, this is going to be a real head turner soon!
miller
Post by miller »
Mustang 22 gallon fuel tank installed with stainless steel straps. I wanted tank serviceable without having to remove bed so it tucks up tight to bottom of frame.
