BobbyFord Short Bed
Re: BobbyFord Short Bed
Here’s a mock up of the scoop onto my modified top plate
I need to raise the overall height by about 3/4”.
The offset is on point.
3/4” too short. I’ll cut the circumference and add 22 gauge sheet metal to adjust the height.
I sectioned the air cleaner base to add 3/4” in overall height. The scoop sticks all the way out of the hood now.
MAK
Post by MAK »
Looking good. :thup: Getting closer.
Nice work with the fabrication to get it in the right location.
Thanks, bud.
67mann
Post by 67mann »
8) Nice work
67mann wrote: Sat Aug 03, 2024 2:08 pm8) Nice work
Thank you.
I got the trim ring done yesterday. Matches the truck hood contour now.
I guess I’m not going to use this blue hood. I had another in the shed. I made a template off of the blue hood but still took 45 minutes to measure and re-measure.
Nice work and looking good.
Dumb question - would the hood have closed on the shaker scoop prior to mods?
DuckRyder wrote: Wed Aug 14, 2024 7:10 am Nice work and looking good.
Thanks, Robert
I'm not exactly sure what you're asking. Are you asking if the hood would've closed before I added the 3/4"?
I have this crazy idea of putting one on but being under the hood so I was asking if you just put the shaker on the engine would the hood close normally.
I thought I saw some pictures where you had a bar across the engine compartment but can’t find them.
DuckRyder wrote: Wed Aug 14, 2024 8:15 am I have this crazy idea of putting one on but being under the hood so I was asking if you just put the shaker on the engine would the hood close normally.
No, it definitely wouldn't fit. Another thing, I looked online and the scoop kit that I bought is no longer available. They make one with a fiberglass flapper plate and a fiberglass scoop. The scoop I have is alloy and the flapper plate that I chopped up is metal. I bought mine in 2016 and the part number on the box is C9ZZ-9600-D
Thanks Bobby
Good to see you back on the truck.
My problem is that my 63 is completely torn apart and I'm trying to work on two trucks at once... :cry:
