67 F100 Crown Vic suspension, Diesel engine, disc brakes
carcrafter22
Post by carcrafter22 »
I like your sig Thunderfoot, I agree. My ford has ford, chevy, and sadly even dodge parts, but only 3 of them :D :D :D
67 F100 sc/sb 07 Crown Vic IFS, 94 Lincoln Mark 8 IRS, isuzu 3.9L diesel w/ HY35 & HX 52 compound turbos and 370cc custom injection pump,T56 6spd trans, 18" 07 dodge magnumm wheels, old air products A/C (for a 66 mustang LOL). 32 mpg's so far, around town
wt4speed#2
Post by wt4speed#2 »
I would like to see this one in person . I'm just close enough I might just make a point to do so.
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
'69 F-100 "Stepper"(currently in a bigillion pieces )
wt's ride
thebucket
FormerMarine1981
re: 67 F100 Crown Vic suspension, Diesel engine, disc brakes
Post by FormerMarine1981 »
I am very interested in the CV swap. I would like to see more pics of the mounting if you get a chance. Thanks.
What we do in Life, Echoes in Eternity
carcrafter22
Tony feel free to stop by you can pm me your phone number and I can calll you when I get back from east texas if you want.
Here is a link to my photo albumn so you can see all the photos I have posted on the internet so far.I would post some pics but the wireless internet I am using is extremely slow out here.
http://good-times.webshots.com/album/562648372VFJwCq
wt4speed#2
carcrafter22 wrote:Tony feel free to stop by you can pm me your phone number and I can calll you when I get back from east texas if you want.
pm on it's way
Tony B.Image
DFW Area
"Someday...
Member#'s 236 & 403
wt's ride
thebucket
dcbullet
Post by dcbullet »
Fantastic project! I love all the swaps you have done with the goal of a comfortable daily driver.
That really turned out nice. There's a wrecked merc down at the farm and I was eyeing that front suspension and thinking how easy it would be to put in a street rod and here it is... The disc brake rear is going into the ranchero in the near future.
Jamie
carcrafter22
Here is the new bezel I threw together in about 20 minutes I will be taking some more aluminum to the local fab shop so they can cut the aluminum straighter so there is a perfect gap on all sides, I will use this as a template for the perfected one.
AK F100
Post by AK F100 »
Nice job. That's just about what I'm gonna do for mine.
GPBFD Pyro Maniac
Daily Driver: 1974 F100 4x4 (ride'n on 8-Luggers) Build in progress
1997 F-350 Crew Cab 4x4, 7.3L Diesel SOLD
Pile-O-Parts: 1968 F100 - 2WD Shorty SOLD
Looking for a new project 57-60 Ford Truck
Jason
Post by Jason »
did you have to mod the gas tank at all or just the sending unit?
1967 F100 SWB step-side, 300" 6cyl, T-18 transmission and Dana 60-3 rear end with 3.54s
Mooosman
Post by Mooosman »
I know the CV crossmember has a couple guide pins sticking out of it. Is there an existing hole on the frame that you used for these pins to help line up/center the crossmember in the frame? Did the alignment shop have any problems aligning it?
Looks like a really neat idea. Much easier than swapping in a Mustang II clip...
Nick :thup:
1972 F-100 Custom SWB
carcrafter22
The fuel tank is untouched since it is made of plastic I didnt want to mess with it although it would have been easier if I did though...... I think :? I just had a custom aluminum sending unit made to fit. All went well and now its a factory like system that is easy to service like factory.
As for the crossmember I just put the center of the wheel bearing in the same place as the original wheel bearings. I then marked it up and drilled my holes. None of the original holes lined up so I had to drill everything but it was pretty easy. This swap could be done in a weekend by a competent hands on kind of guy with a good torch or plasma cutter and a decent drill and a small welder.
I know this is gonna sound weird but I havent gotten an alignment yet. I know I know but I just havent gotten around to it even though I have about a couple hundered miles on it already. The truck handles very flat around the turns, drives smoth as silk on the roads and stays almost perfectly straight on the highway at speeds up to 95mph ( highest speed tested so far :D) it doese have a very slight pull to the left but its just barely there. That pull could also be due to the road not being perfectly level. I have driven factory new cars with more pull to it than this thing has even with no alignment. I guess it paid off measureing 20 times and cutting once.
HRDROKN
Post by HRDROKN »
Great job...... I bet that thing pulls some sweet mpg's!
:thup:
'69 Ford Cummins Crew Cab... Built 6BT main & head studs, ported & oringed head, springs, Ti retainers, marine cam, tweaked P7100, 4K gov kit, NV4500 w/1.375" input, Southbend 3600# DD clutch, NP271 w/SYE, D60 HP front, high steer, 16" coilovers & 4-link, D80 w/disc rear, 4.10's & LSD, spinning 38" x 14.fiddy's on classic slots..... more coming!
http://www.fordification.com/forum/view ... hp?t=23267
carcrafter22
Yes sir it does,I am figuring roughly 30mpgs right now and its fast enough to beat an 06 cummins off the line and at highway speeds. I love this thing. I am going to enter it in a small car show of about 40 cars. I will be registering in the under construction category. :D We'll see how it goes.
lifted72
Post by lifted72 »
Just need to throw my running gear under that thing!!! Love the pickup dude, great work so far. So how hard was that EZ wiring to wire in? Did you switch to a new chevy steering column?
POLISH EVERYTHING
