Yes! There was already a crack around that one rivet, and I used a hammer to make a companion crack around another one (to better balance the condition of the box). I found it quite challenging to remove the rivets without damaging the fiberglass/plastic half and the metal half! I tried a punch (bad idea), a cut off wheel on a die grinder (semi-bad idea), and finally a regular little grinder bit on the die grinder (the most effective of all).fireguywtc wrote:For those rivets, yes I had to grind them out and pull up the little tabs when I could to get those old things out. You need to be real careful here because you can obviously cause damage to the fiberglass or whatever the box is made out of. I can see in your pic its already starting to crack.
But removing the rivets was like giving a chipmunk a dental filling with Joe Montana hitting the Instant Playback button all afternoon.
The spoils:
Thanks for letting me know! Now I don't feel like as much of a clod for unintentionally roughing it up. Since I hadn't seen this step mentioned in your project updates thread, I figured you'd used high powered lasers for the job!fireguywtc wrote:I have a confession here as I broke mine off pretty good so I ended up going to a junk yard and finding another box in better condition just to get the plastic part, I was more careful with the second one. I am sure it can be fixed with some kind of a glue or resin.
Thanks Bill!fireguywtc wrote:Good luck and hope yours comes out good too!
After the rivet battle, I popped the top off. The llama tongues look improved over their condition in my imagination, but I'll still be happy to make the area ship shape.
Questions:
- Bill and other friends who did the rebuild, did you notice one or more of the pins that the flaps swivel on being held in by one of these funny little clips?
http://www.robroygregg.com/Number50/IMG_3918s.JPG
Only one of the pins had this clip on mine--the others either never had the clip from the factory, or the other clips came off long ago. - How in the world do I remove the pins from the metal cover? I can see in Bill's photos that the flaps shouldn't be removed from the pins, but how does the pin and flap combo pull out of that piece of sheet metal? It looks like the ends of the pins may have been bent after this area was assembled (at the factory).
Robroy
