C6 speedometer drive gear needed
- BobbyFord
Re: C6 speedometer drive gear needed
Just go give them the number that I posted. It's a generic seal number.
- evan_flatt69
Well I got the end piece off. I found no evidence of a drive gear. But I did find that the yoke was a bit scratched and gouged up. The drive gear slide over the yoke and make contact with the driver gear correct?
Here are the pics:
Here are the pics:
1969 F-100 Short Bed Custom Cab 390
1985 BMW 635CSi
1985 BMW 635CSi
- BobbyFord
Should be a metal drive gear sandwiched between two of those spacer rings...
- evan_flatt69
Nothing is there. Nothing to be seen. Looks like I'll have to find one.
1985 BMW 635CSi
1985 BMW 635CSi
- BobbyFord
I've been doing some research and I think the short tailshaft C6 may use the same speedo drive gear as the T-18, T-19 manual transmissions. It sure looks the same...> http://www.ebay.com/itm/FORD-BW1356-BW- ... 49&vxp=mtr
I'm not sure how many teeth yours should have. See if you can determine how many teeth were on the chewed up gear and then refer to this chart...> http://www.fordification.com/partnos/sp ... 4spd01.htm depending on your tire size and rear end gear ratio.
Or...these guys should be able to help you get what you need...> http://www.transmissioncenter.org/Ford_ ... _Gears.htm
- evan_flatt69
Thanks for the info Bobby. Looks like I'll need a 7 tooth drive gear if I'm going to try it. The gears being plastic on metal shouldn't hurt should it? And how exactly does it stay in place?
1985 BMW 635CSi
1985 BMW 635CSi
- BobbyFord
The drive gear goes in between the two rings on the shaft and the yoke and nut hold it all together.evan_flatt69 wrote:Thanks for the info Bobby. Looks like I'll need a 7 tooth drive gear if I'm going to try it. The gears being plastic on metal shouldn't hurt should it? And how exactly does it stay in place?
- evan_flatt69
Hmm. Only one ring.. I can probably make one
1985 BMW 635CSi
1985 BMW 635CSi
- 70_F100
Looks like they left the drive gear out and the yoke got against the driven gear. Hopefully, the extra end play the output shaft would have had didn't mess up any internals.
The P/N for the driven gear for a 69 is C5TZ 17285-C (8 teeth) for about all rear axle ratios and tire sizes. Green Sales has one: http://www.greensalescompany.com/ Let me know your ratio and I'll verify that this is the correct one.
Can't really tell which driven gear you have, but it looks like either 18, 19 or 20.
18: 01T 17281-A
19: 01T 17281-B
20: 01T 17281-C
Couldn't locate any of these under those numbers, but the numbers may have been superceded.
Hope this helps!!
18: 01T 17281-A
19: 01T 17281-B
20: 01T 17281-C
Hope this helps!!
That's not an oil leak That's SWEAT from all that HORSEPOWER!!
- evan_flatt69
Thanks for the lead 70_F100! I tried calling them today about ordering it but I guess they're closed for the 4th of July. I'll try again tomorrow.
1985 BMW 635CSi
1985 BMW 635CSi
- 70_F100
Before you order it, let me know the rear end ratio and tire size so I can verify that's the right one!!
- evan_flatt69
Oh right! it's open 3.25 and 27.5" tires
1985 BMW 635CSi
1985 BMW 635CSi
- 70_F100
That should be correct for the drive gear, then.
- evan_flatt69
Thanks for the help guys! I ordered the gear today and it should be here monday. 65$ shipped. Kinda hurts but I was just surprised to find one
1985 BMW 635CSi
1985 BMW 635CSi
- BobbyFord
