Update 4/19/2015 1972 F100 SWB Weekend Project Part 2
Alstoyz
Re: updated 1-29-2014 1972 F100 SWB Weekend Project Part 2
Post by Alstoyz »
Very nice work!!! It's looking really good. :thup:
1970 F-100 SWB Tubbed
1971 F-350 4X4 (traded for 71 crewcab)
1971 F-250 Crew-Cab Dually
1972 F-100 SWB 4X4
1972 F-350 Crew-Cab 4X4 Dually
2001 F-350 Crew-Cab Short Bed 4X4 Dually
jp2005
Post by jp2005 »
Thanks guys! The motivation helps! :wink:
Thanks JP! Ms. Cordova is a factory 1969 Ford F100 Ranger with a 390, Front disc brakes, Cordova copper orange, behind the seat box
Heirloom
Post by Heirloom »
:yt: :pop:
~Heirloom
'68 F250 360, 4 spd Project Thread!
Plans are for a stout 400, C6, 3.54 gears, 33" BFG AT's, bucket seats and custom console. Final assembly, nearing start up...
"Those who hammer their guns into plows will plow for those who do not."
~ Thomas Jefferson
"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves."
~ Abraham Lincoln
tylerb43
Post by tylerb43 »
Looks great!! Can't wait to see more! :clap:
jp2005
Re: updated 2-27-2014 1972 F100 SWB Weekend Project Part 2
Post by jp2005 »
Well finally after getting my daily all straighten out I was able to start working on my master piece again. I was able to reply a coat of paint to the engine bay radiator support, steering gear box and under carriage. This weekend I'm going to apply more paint and I have to take my 390 back apart knowing what I know now on sealing intake gaskets. I'm just glad I didn't run it yet, its all a learning experience but a life time of knowledge! :thup:
Also installed new axle pivot bushings, Geez what a crap job to perform. My new bushings actually came with metal shells, so I had to drill out old rubber. And then cut the old metal shells out. Grind some of the new metal to even get them in the hole. To reinstalll I had to rent a press tool, don't even bother trying to use a hammer!!!!Here's a couple pictures!!!
jp2005
Post by jp2005 »
:thup:
Mancar1
Post by Mancar1 »
Following along with interest. Thanks for posting. :thup:
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
jp2005
Updated 6-9-2014 1972 F100 SWB Weekend Project Part 2
Post by jp2005 »
This update is long past due, since the last post I've installed engine, transmission, aux fuel tank/lines, battery relocation and drive shaft.Next well be the headers, pulleys and front clip. My goal is to fire this big BLOCK by the end of June. Ill post some pictures here soon. Thanks for your support guys! :fr:
jp2005
Post by jp2005 »
Life is crazy when you have a project going, family and friends all want your time! One day this truck will run just have to stick with it and not let it set in my garage for 50 years!
jp2005
Post by jp2005 »
Snapped a few photos
jp2005
Re: Update 6/29/2014 1972 F100 SWB Weekend Project Part 2
Post by jp2005 »
Installed headers, radiator support, radiator,inner fenders, pulleys, ignition wiring and carb what alot of work! :fr:
Looking to fire it next weekend! I take a video and post it!
jp2005
Update 8/26/2014 1972 F100 SWB Weekend Project Part 2
Post by jp2005 »
Well thought I posted a update. Installed the whole front clip and it's running and driving now. Next is going to be interior work! I'll post some pictures soon.
jp2005
Re: Update 1/29/2015 1972 F100 SWB Weekend Project Part 2
Post by jp2005 »
Its been awhile guys, I haven't did anything new with truck. I got kind out burned out last year and took a break. But next is exhaust and hopefully start interior this year. Had a few life changing experiances, but all good. Ill keep you posted.
Thank you :fr:
jp2005
Re: Update 4/19/2015 1972 F100 SWB Weekend Project Part 2
Post by jp2005 »
New Exhaust has been installed and got my seat recovered. Also temp painted front clip just so it matches. Aleast until I can a professional paint job. Ill try and post some pictures soon, but the old girl has come along way.I almost shed a tear of happiness when I drove it with the new exhaust. Just ever thought all the work would finally get done. :)
jp2005
Re: Update 9/4/2015 1972 F100 SWB Weekend Project Part 2
Post by jp2005 »
Back at it redid headliner and painted door panels. :fr:
