1967 F-100 project
- 67nukeford
Re: 1967 F-100 project
Now starting to get the door post back together. Welded on the Passenger side, then coated the welds over with POR-15. All of this will be coated with epoxy primer, then a coat of black paint.
- 67nukeford
And then the driver's side....
- Petewrench
![Popcorn :pop:](./images/smilies/icon_popcrn.gif)
"WARNING! Being Hit with The "Brick Of Life", is just a hint that you are about to be run over by the "Boulder Of Being"!"
1967 F-100 Base Long bed. 390 4Bbl, NP435 4Spd, Manual Steering, Manual Brakes, A/C. (BlueBeast).FOR SALE-NOT!
1967 F-350 C&C, 159"WB.(Donor Truck)
1967 Mercury Cougar Standard. 5.0 HO, RUG-E 4 Speed, Factory Triple Black, Console Car.(SOLD)
![Beating a dead horse :bdh:](./images/smilies/deadhorse.gif)
![hornet's nest :hn:](./images/smilies/hornest.gif)
![rant :rant:](./images/smilies/rant2.gif)
![White flag :wf:](./images/smilies/icon_whiteflag.gif)
![Driving :drive:](./images/smilies/icon_steering.gif)
- 67nukeford
Finally finishing up the last of the welding on the door support section. Mocked up the vent boxes, with the cowl on, so I know everything will line up perfectly. There are holes for alignment, I'm assuming they used at the factory. I just put a guide pin in the hole, and then clamp everything down. Came out perfect! I'll get the cab primered, and the cowl area painted, before I weld the cowl panel back on.
- Heirloom
![Surprised :eek:](./images/smilies/icon_eek.gif)
That makes my rust replacement look like childs play! Nice work my very dedicated friend.
![Clap :clap:](./images/smilies/icon_clap.gif)
![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
~Heirloom
'68 F250 360, 4 spd Project Thread!
Plans are for a stout 400, C6, 3.54 gears, 33" BFG AT's, bucket seats and custom console. Final assembly, nearing start up...
"Those who hammer their guns into plows will plow for those who do not."
~ Thomas Jefferson
"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves."
~ Abraham Lincoln
~ Thomas Jefferson
~ Abraham Lincoln
- 67nukeford
Thanks Josh. It's been an awful lot of work, but I think it'll be worth it in the long run!
Great work, Pat! Hat's off to you for all that patience and perseverance. ![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
- 67nukeford
Thanks Randy, I appreciate it! Used chemical stripper on the cab this weekend. I was just going to sand the paint, but there are two coats, and it's in pretty bad shape, so I stipped it ( I hate using that stuff, what a mess!), and I'll go over everything with some 80 grit over the next few days. Hoping to shoot epoxy on Sunday.
- 67nukeford
Well , Mother Nature cooperated, and gave me a very nice weekend. So, after spending 8-10 hours with my DA, the cab was stipped down.
- 67nukeford
With all of the paint gone, I did find a few spots I wish I had known about earlier. Someone mashed this cab up pretty good. Then, instead of pulling the dents (although, it looks like they tried in one spot), they just filled them with bondo. Damn stuff was 3/8-1/2 inch thick on the drivers side of the cab!
- 67nukeford
Finally coverd in epoxy. If I can get another good weekend, I'll get the cowl and dash in epoxy also. I'd like to get the doors done, but I'm thinkng I may not have enough time before the weather changes.
- JWW
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
My project: http://www.fordification.com/forum/view ... &sk=t&sd=a
2004 F150 Crew Cab
Great start! Keep at it. ![Clap :clap:](./images/smilies/icon_clap.gif)
- jimmy828
That is one clean cab right there. ![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
- 67nukeford
Just a quick update on a few things I"ve gotten done. Sprayed the inside of the cowl area with 2K Chassis Black. Wanted something fairly durable, and this should do the trick. I'll also spray the underside of the cowl. Also prepping the dash for epoxy, I had to fill some holes that a PO had drilled for various who-knows-what!
