The Green Beast
ford4x4fun
Re: The Green Beast **Oil Pump In Lots Of Parts Cleaned**
Post by ford4x4fun »
Hey Jeff,
Yeah I am going to replace the freeze plugs after I paint it. Paint just doesn't seam to stick to them. So I will do that after I am done with it.
I didn't even know they made an oil pump primer. I will get one just to save any problems with the motor. I am going to run the motor for about 75 miles when I first get it running than change the oil again I blew it out real good after cleaning up the motor but I am sure there is a lot crap still inside it. Than probably about a 4 to 500 mile run and changing it again. I am really nervous after having it open I don't want to jack anything up after all of this work.
OH, and yeah we had a frost on this morning I think about 28 degrees. We are suppose to have another one tonight.
CNR Radio Instructor
US ARMY Retired
1971 Ford F100 4x4 (390)
2015 Ford F250 Crew Cab 6.7l
basketcase0302
Post by basketcase0302 »
Might want to verify this is the right one:
http://www.summitracing.com/parts/SUM-901011
You know it's cold when it's that...cold in florida! Image
ford4x4fun
Jeff, your not joking it was a cold morning again today. But the good news is by 10 it is back up to the mid 50's.
OK, UPDATE:
10 hours of working on these things over 3 days. Hand scrubbing because I can't get my sand blaster working quite right at the moment. But here they are.
The stuff I used. Once I got the paint remover they finished up in about 3 hours. And the real course steel wool helped a lot too. The rubber gloves are to ease the burning from playing with the paint remover.
US ARMY Retired
ford4x4fun
Re: The Green Beast **10 Hours Spent On Recent Update**
My best helper let me down.
US ARMY Retired
ford4x4fun
Re: The Green Beast **My Best Helper Let Me Down w Photo**
OK Gentlemen,
So this is what I got done the second half of today. I wasn't planning on getting this far so it is nice to be ahead of schedule just a little. But I still don't think I will have it put back together and drive her into work on the 9th.
The Motor Prepped For Paint I.E. hopefully I got all the oil and grease off of it. Me and my youngest worked on it for about 3 hours this afternoon.
Oh and the quality of photos is a little bad because I lost my sun light.
A lot of painted parts!
And last but not least the dreaded springs. I don't know if any of you all have every painted springs with a brush but it isn't fun. Hopefully the POR15 holds up to the flex of these things.
So now cook dinner and clean up my mess. I hate it when the wife works late!
US ARMY Retired
basketcase0302
Re: The Green Beast **5th Jan Update**
I'd flat out fire that helper! Sleeping on the job aint' kool! :lol:
67mann
Post by 67mann »
basketcase0302 wrote:Might want to verify this is the right one:
You know it's cold when it's that...cold in florida! [ Image ]
Hey billy...all this is,is a glorified screwgun shaft...just did it myself as a matter of fact. Being a homeowner/handyman...you must have a cordless drill(or regular) kicking around..throw one of these.. http://www.homedepot.com/Tools-Hardware ... ogId=10053 and your good to go or if you have the smaller ones kickin around..tape'm together :thup:
ford4x4fun
Engine Primed :woohoo: 8 hour wait till I can't put on the ford blue!
On a side note after I took the picture I primed the harmonic balancer too!
US ARMY Retired
ford4x4fun
Re: The Green Beast **Looking Like A Ford Motor**
Here is the first coat. Just finished the second coat on her. May need one more but I look at is I should just keep putting coats on till I run out of Ford Blue paint. If anyone is ever going to do this and use POR15. A couple lessons.
A. Buy yourself some good brushes, the ones they supply start losing bristles rather quickly and than you end up with bristles permanently attached to your motor.
B. If you have the ability to spray this stuff do it! This would have been done hours ago if I had the equipment to do it.
C. Also get yourself a good pair of gloves. I bought the yellow one like grandma use to use for scrubbing dishes. The ones that come with the kit tear up real quick as well.
So on a side note I am glad I am not doing this for show, or I would never win. But for a 4 wheel drive toy it sure will look decent!
And without further interruptions. Here she is with one coat. The second coat is one her drying as I type!
US ARMY Retired
Bob
Post by Bob »
Ting...
Very sparkely...!!
ford4x4fun
Bob wrote:Ting...
Very sparkely...!!
Another little mock up but again I am losing my daylight!
Eventually I am going to do the dual snorkel set up with a stock air cleaner. I have the air cleaner and one snorkel just need to get another one!
US ARMY Retired
1971ford
Post by 1971ford »
This thing is going to be nice!!!
-Ryan
Excellent work! Looks great!
basketcase0302
Looks like you made some good progress! Did you light a fire under that helper's butt?! :lol:
Engine looks nice man, you won't want to take it to bubba's after you're done now!
https://www.facebook.com/pages/Bubbas-M ... 6219376293
Your wife and kids will love Bubbas! :thup:
ford4x4fun
Thanks Gentlemen.
Jeff yeah I figured out that if I let him sleep for 23 hours he really works hard for that one hour! :lol:
OK an update.
Cab Mounts Welded in place going to clean them up today.
Motor Mount welded and fixed.
And the crossmember was a little jacked up from the PO before my dad hitting a tree my neighbor fixed that too.
US ARMY Retired
